jdm d15b smoking like a bandit
Old Apr 23, 2011 | 07:50 PM
djsimm89's Avatar
Default jdm d15b smoking like a bandit
Ok so I blew my stock d15b7 in my eg so I picked up a jdm d15b from jdm engine depot put the.motor in fixed some little stuff and it smokes like crazy its Weired cause sometimes at startup its fine then I drive and ill see clouds of smoke then sometimes there's no smoke at all I checked the oil level its good I checked the coolant its good to Wat could be the issue everyone is saying headgasket but if the coolant is good how can it be a headgasket someone please help
94EG8's Avatar
Seagull Management
Default Re: jdm d15b smokeing like a bandit
What color is the smoke?
Old Apr 23, 2011 | 07:52 PM
djsimm89's Avatar
I guess I can't realy explain it its like a white smoke which I kno means antifreeze but the coolant level is un altered
Old Apr 23, 2011 | 07:56 PM
94EG8's Avatar
Seagull Management
You may want to check and make sure you haven't got any vacuum and coolant lines mixed up with one another. Also check for the presence of exhaust gas in the coolant and do a compression test.
Old Apr 23, 2011 | 08:08 PM
djsimm89's Avatar
No coolant lines are mixed up wit vacumes and exhaust gas in the coolant??????
Old Apr 24, 2011 | 08:33 AM
djsimm89's Avatar
Bump Tttttttttttttttttttttttq
Old Apr 24, 2011 | 09:29 AM
Steebhouse's Avatar
bump, we`re waiting...
Old Apr 24, 2011 | 09:47 AM
DeeC2's Avatar
10 Year Member
Icon3 Re: jdm d15b smokeing like a bandit
i got one a while back i think you just need to let it all burn out when they store the engine they run this greese **** through it so that when it sit in a warehouse or were ever, it's internally protected, when i started mine it smoked down the block but i let it idle for about 20 min after about 15 min it stopped smoking
Old Apr 24, 2011 | 07:02 PM
djsimm89's Avatar
I've had the motor in for a week changed the oil in it twice cause it was black as **** the oil is back to gold after flushing 7 quarts threw the motor buy still ***** smoke but no overheating no change in coolant and I noticed ill start it up it Will b fine and when I drive up a large incline it smokes very heavily idk Wat to do
Old Apr 24, 2011 | 07:46 PM
2000siturboR's Avatar
here's a question do you have any cels first?
Old Apr 24, 2011 | 10:09 PM
billllll23integra's Avatar
check your compression, then c if ur pcv is working mayb also..
Old Apr 24, 2011 | 10:44 PM
djsimm89's Avatar
Nope no cel's
Old Apr 24, 2011 | 10:49 PM
djsimm89's Avatar
I'm doin a compression test tomorrow and if it was PCv it would be black smoke I presume but ill check that to now any one know Wat headgasket to use for the jdm d15b and please don't guess lol
Old Apr 25, 2011 | 03:43 AM
djsimm89's Avatar
Ok so I leave work this morning and I'm driving no smoke I get to a hill tons of smoke back to flat ground no smoke hill again smoke so it only smokes when motor is on an incline do maybe that will help someone to figure out Wat the **** is wrong with this motor
Old Apr 25, 2011 | 03:45 AM
grumblemarc's Avatar
The Grumpiest
No. The compression test will do that.
Old Apr 25, 2011 | 03:47 AM
djsimm89's Avatar
Yeah my boys shop opens at 10 I'm taking it there wen he opens
Old Apr 25, 2011 | 07:59 AM
Former User's Avatar
Default Re: jdm d15b smoking like a bandit
Are you sure it's not blue smoke (=burning oil)?
Old Apr 25, 2011 | 08:35 AM
djsimm89's Avatar
Compression test done 180 across the board
Old Apr 25, 2011 | 11:56 PM
Any sohc vtec head gasket. just as long as the motor was never bored.
all d15/d16's have the same bored at 75 mm the difference in displacement is the stroke. b series are the same way they all have 81mm bore with just longer stroke. ( b20's are a exception with a 84mm bore).
Old Apr 26, 2011 | 02:05 PM
djsimm89's Avatar
thanks u sir
ok now after compression test we checked the map sensor and the o ring was missing after replacing then we changed the purge solinoid on the i/m cause it was broken changed those and reset the ecu the idle sits at 2000 rpm and the idle adjustment screw was turned down as well as the iacv cleaned as fat as the fast idle valve its bypassed so no cleaning of that needed cant fix the idle AND NO I HAVE NO VACUME LEAKS also wat valve seals for the jdm d15b and can i install them without removing the head
Old Apr 26, 2011 | 02:24 PM
frankenghia's Avatar
silly question.... Did you overfill the oil? Also did you have the oil pan off and see if the windage tray or whatever its called on a honda was in there?
Old Apr 26, 2011 | 04:08 PM
djsimm89's Avatar
oil is not over full and no my oil pan is not off
Old Apr 26, 2011 | 05:52 PM
djsimm89's Avatar
Bump for some help
Old Apr 26, 2011 | 06:52 PM
hyperblu's Avatar
the tilt of the engine probably doesnt have anything to do with it. If I had to guess it's when there is a load on the motor...You could be running very rich...
Old Apr 26, 2011 | 06:53 PM
hyperblu's Avatar
check your plugs and see if they are filthy...
96honda_EK
Sep 15, 2010 01:07 PM
Ozne99
May 27, 2008 08:36 PM
h22pwr
Jun 14, 2005 07:54 PM
akaEsCo01
13
Dec 8, 2004 01:27 PM
slam!butter!
Sep 28, 2001 12:41 PM
