b20vtec bad idle and choke on rev's please help???
Old Apr 23, 2011 | 06:36 PM
superhatchbackbros's Avatar
Default b20vtec bad idle and choke on rev's please help???
i just put the motor in today and put it all together and it starts right up.. it has low idle surge like 1200rpms when lil warm it jump 1200-1800rpms and drops back down! was thinking tb gasket leak?? i have a victor x intake manifold and a sk2 throttle body with a 68mm thermal gasket! could this be the problem? also the victor x manifold iacv weird looks like its universal d and b series iacv. i think i have a d series one on it right now. could that be a problem? also i put a new blox tps on it and did the ohms reading and they are correct.48ish closed and5.00 wot! or is it diff readings i should have? it seems to hold fuel pressure i set it for 45ish psi right now where should it be exactly? and when i give it short revs it wants to choke and die? wtf could be that problem? if i hold the gas down rev it up to like 3000rpms it seems to rev fine.. i dont get it can someone please give me some feedback.. i dont wanna f this engine up! well hope someone can help me.. thanks in advanced HONDA TECH MEMBERS
Old Apr 23, 2011 | 06:38 PM
Default Re: b20vtec bad idle and choke on rev's please help???
ps everything is brand new! also keep trying to burp the engine's coolant system thinking thats the problem and also i dont have 02 sensor hooked up yet and im not geting no check engine codes? weird and im running a stock p28 at the moment. is that bad to do? should i use my lsvtec ecu to start it up and see what it does? or just get a stock p72 gsr ecu? maybe the p28's messing with the engine? please help
Old Apr 23, 2011 | 09:18 PM
bump anyone??
Old Apr 24, 2011 | 10:45 AM
really noone can help me or give me some kinda feedback?
Old Apr 24, 2011 | 10:48 AM
HondaPartsHero's Avatar
Technical Hero
voltage should be .5 closed, 4.5 wide open. Any check engine lights?
Old Apr 24, 2011 | 03:09 PM
ok i got the voltage right thanks and no codes.. its weird i just started it up and it ran like 1200 till warm up and then it started going up and down not by alot tho.. hmmmmm
Old Apr 24, 2011 | 04:18 PM
also i had it started and it idle high like 1200 and i disconnected the iacv and it keep runing as it was then soon as it warms up and then started to surge i diconnected the iacv and the car puttered and shut off! is that a bad iacv?
Old Jan 26, 2012 | 12:19 PM
MGates112's Avatar
If you are using a d series harness, the iacv plug converts over from a 3 plug to a 2 plug, so that might be your problem right there.
Old Jan 26, 2012 | 12:25 PM
grumblemarc's Avatar
The Grumpiest
Maybe. But I think in almost a year he should have figured it out.
Old Jan 26, 2012 | 01:03 PM
MySickSi's Avatar
Lmfao agreed^
andybmuzik
Aug 9, 2013 08:23 PM
apbtwhiskey
Apr 5, 2013 01:51 PM
95dc2teg
Sep 11, 2007 05:49 PM
ls-t del sol
Sep 27, 2004 11:49 AM
Integra_Boi
Aug 21, 2002 02:17 PM
