88 crx installing header need help asap
Old Apr 23, 2011 | 02:54 PM
Non Phixion's Avatar
Default 88 crx installing header need help asap
I'm in the middle of installing my new header and i have everything unbolted and ready to pull it out until i realized that there was another sensor right behind the first one i removed.
My question is There is only one o2 sensor on the new header and further down on the header to where the sensor wouldnt even reach. what am i supposed to do? is it ok to just extend the wire and only use one sensor?
Old Apr 23, 2011 | 04:21 PM
Tyson's Avatar
Default Re: 88 crx installing header need help asap
its fine to use one sensor.
the o2 sensor wire can actually go and reach to the rear of the engine if you route the wire over the tranny. you dont have to tho. either one will work.
use an old o2 sensor to plug the one you dont use.
Old Apr 24, 2011 | 09:36 PM
Yo thanks for the info man.
I got the new header on and removed one of the o2 sensors and then cut and extended the one i was going to use.
I was expecting a little more out of the header lol......
hondafdj444
Feb 12, 2014 11:23 AM
MainStreamHonda
Aug 9, 2011 09:36 AM
mugenpovver
Feb 16, 2008 12:56 PM
newBcrxer
Jun 21, 2004 08:46 AM
ddua
Sep 24, 2003 05:07 PM
