What IGN box/setup do you run?
I am in the market for an IGN box for my new setup. I have my eyes on the new MSD digital 6A box. PN 6201. Will it hang with 30Ish PSI. I dont need alot of features because I can do everything else with the ECU. Was thinking about stepping it up to a digital 7 box, but if the 6a will be sifficient then Ill save some $$ what setup do you have?
mine: Stock dist/ectune/2.0L/id2200/s400-71/e85.
Most people are going to tell you that the M&W stuff is the best. It has a big advantage in eliminating the ignitor. Maybe someday I will make the switch, but for right now I run a MSD Digital 6 Plus with HVC-II Coil. OEM Dizzy, OEM wires, and NGK Plugs. Never had an issue.
As a sidenote, my car is a high 10 at best, so maybe as the power gets turned up my opinion will change.
im running the m&w pro 10 works great! no ignition break up or nothing! I was running the digital 6. kept having igniter problems. contact t1 race development the for the pro 10 kit
http://t1raceparts.com/index.php/en/...ro-10-kit.html
Not to threadjack but if I were to change from just a modded dizzy using an msd blaster coil to running the MW pro10 what all do I need to change. Can the MW be used with the msd coil. I see most using the crane.
Yes but you have to use the "7 series coil" which is the big red one.Im selling my Pro 10 and MSD coil.Pm me if anyone is interested...
