What injectors should i use and at what psi?
Old Apr 23, 2011 | 11:48 AM
HOM DON's Avatar
Default What injectors should i use and at what psi?
heres my setup
b20b4 block
rs machine pistons 84.5mm
stock b16a3 (pr3-1) head
type r throttle body
255lph fuel pump
I was just wondering what injectors are ideal for this setup? and what psi should i set my FPR to?
thanks in advance
Old Apr 23, 2011 | 12:17 PM
bambam's Avatar
Default Re: What injectors should i use and at what psi?
Fuel pressure should be set to what the injector manufacturer specifies for that injector.
Old Apr 23, 2011 | 12:40 PM
HOM DON's Avatar
hmmm that makes a lot of sense. I was told by one person to go 310cc and another to go 440cc. I'm not sure which one to use.
Old Apr 24, 2011 | 04:48 AM
bambam's Avatar
440 cc would leave more room for growth. You will have a means to tune correct?
Old Apr 25, 2011 | 03:27 AM
anothersickhatch's Avatar
310's will work. I always shoot for a larger injector just in case. I would talk to a tuner that you plan on using in the future.
Old Apr 25, 2011 | 04:34 AM
DDTECH's Avatar
310s @ 50psi. you have nothing else in that motor that requires much bigger..
better cams, exhaust and header probably would require a move up but as it sits.. 310's will be fine.
Old Apr 25, 2011 | 09:48 AM
HOM DON's Avatar
i would like to have a bit more room to grow. perhaps i might get cams a little later on and ungrade my valve train etc. I will definately get a tune for this build. I will be running a phearable basemap just to get it to the tuner. This is totally off topic but I was wondering if its safe to run a phearable basemap during break in
Old Apr 25, 2011 | 10:02 AM
95skunkedgsr's Avatar
just break it in on the dyno and call it a day
Old Apr 25, 2011 | 10:35 AM
bambam's Avatar
You're going to get differeng points on this as well. I refuse to start a car up with fresh rings/cylinders or any aftermarket additions that affect fueling/airflow/compression without a wideband and means to tune.
I would check with the manufacturer of what ever injectors you decide to go with for the recommended pressure to run them at. Running outside of this recommended range can affect the designed spray pattern of that particular style injector. This can affect fuel atomization. Increasing fuel pressure is never the correct means to compensate for requiring more fuel, although it is an accepted method. Increasing injector pulse through tuning is the proper way.
Old Apr 25, 2011 | 09:40 PM
HOM DON's Avatar
Dang... The tuner is so far away
Old Apr 26, 2011 | 03:49 AM
negusjuda's Avatar
im using 370 cc injectors in my b20vtec with tuner 2 cams and hytech header aebs intake mani and 3 inch exhaust
Lonewolf1983
37
Jul 9, 2014 01:06 AM
Ek9_Cuhzz
Jun 2, 2010 07:53 PM
1990_integra_DA9
Jun 13, 2008 09:22 PM
stevieteg
Dec 1, 2004 02:09 AM
Islander
Sep 28, 2001 07:17 PM
