Long life clutch
My clutch feels like its wearing out, its easier to depress, and feels loose, and has less friction to grab. b18c/y80lsd This clutch has been on the car for around 6 years: its a clutchmasters stage 3, alas no turbo was ever added but 6 years is very good lifetime. The previous owner told he wore out factory clutches about twice a year on average before he switched to this clutch.
Anyone else have experience with this kind of clutch life?
I figured both of those out before I even got a reply...99% of people probably never use seafoam or change their own oil. Physically doing something and knowing about something are completely different and theirs always little details there to get in the way.
The "good lifetime" is based on previous knowledge that high performance clutches sometimes have less life, others more depending on the application. Twice a year for his last clutches...yeah the guy drove it hard as **** but was probably exaggerating some and thus I exaggerated some too. But in return your dads EX probably doesn't get driven hard, drag raced, auto crossed etc. Nor is it dyno tuned for max hp.
I believe when I last checked the clutch fluid it was brown colored.
I'm asking whats the best clutch, price/performance wise out there? I was surprised that some discussion of that was not in the faq. Also the clutch fluid, is there any benefit to getting something like synthetic there, which one you recommend blah blah etc.
I will surely confirm that the clutch wearing out is actually the problem here before needlessly replacing it. It could of course be dirty, low, leaking fluid etc.
clutches can last 10+ years depends on if you know how to drive or not. I sold my sedan with 280k miles with the original clutch, it was just starting to fade. my chevy 1500 has 225k on the original clutch and it still grabs strong.
If you're replacing clutches twice a year on a stock engine you can't drive, period. Stock clutch should be good for 200 - 300k if you can drive. Generally speaking if you don't abuse a clutch it should be good for the life of the vehicle.
Indeed, we put 400,000 miles on the OEM clutch in my uncle's Toyota work truck in high school. Started slipping at about 430,000. It's still driving last I checked.
my lx has the oem clutch with over 200k miles on it and feels and grabs the same from when i 1st got it.
2 a year is crazy
my mother couldn't wear out an 80s camaro clutch that fast (they are very hard clutches)
2 a year is crazy
I've got 170k on my 96 hatch original clutch, no slippage. Some may argue but I've used Exedy clutches in all my civics/integras (3 civics 89,89,96, 1 integra 90) with no problems. I've used both the factory replacement and the street/strip discs. I guess it depends on your goals and horsepower.
honda for life
May 20, 2006 10:57 PM
