just installed a mech. oil pressure gauge. ? about readings.
Old Apr 22, 2011 | 01:41 PM
DelsolVted's Avatar
Default just installed a mech. oil pressure gauge. ? about readings.
i noticed at ideal warmed up it reads about 20 psi and in D it reads about 17 psi. is this normal or do i need to be concerned? i have 187xxx on the motor. any help would be nice thanks James
Old Apr 22, 2011 | 01:49 PM
EJ8_Man's Avatar
Default Re: just installed a mech. oil pressure gauge. ? about readings.
Where did you install the gauge, and what motor is it, at what RPM are you getting 20 psi?
My B18C likes to be around 60 psi at 3000 rpm
Old Apr 22, 2011 | 01:56 PM
DelsolVted's Avatar
d16z6 and 8 900 rpm at ideal. its installed where the oil pressure switch was and put a brass t block in with the stock oil pressure switch, oil gauge.
Old Apr 22, 2011 | 02:00 PM
grumblemarc's Avatar
The Grumpiest
I don't have an automatic. Mine sits at 25PSI when idling and shoots to about 50PSI @ 3K RPM.
Old Apr 22, 2011 | 02:40 PM
EJ8_Man's Avatar
20 psi is fine at that rpm
Old Apr 22, 2011 | 02:45 PM
DelsolVted's Avatar
70ish around 3000.
kornerk12
Dec 29, 2007 05:42 PM
ham
Sep 5, 2006 08:29 AM
mister2racer
Jun 3, 2004 03:46 PM
civicridah
Jul 17, 2003 12:09 PM
IGGY
Nov 28, 2001 02:14 AM
