EF My crappy vtakk box
Well I decided i would share this with you guys. This is my first real build. Tired of having a slow crappy looking car, soo my brother threw me and offer i couldnt refuse. b16 head w/o cams and b20z2 block
$250 later and i still have a bunch to spend, bought b16 cams for $15! from a buddy.
Shopping list for now is
B20 head gasket
Golden Eagle vtec kit
b16 intake mani
ARP head studs
ACL bearings
ARP rod bolts
gsr water pump
timing belt
vtec solinoid
Ecu
supertech 12:1 pistons
bisimoto rods
bisimoto header
If anyone can think of something i forgot let me know please!
Oh and what its going into
1990 honda civic STD hatch, with a LS swap and b16 trans on some shitty coilovers..
just snapped some pics of everything i have so far
Ill try and update as much as possible but no job :/
B20 head gasket
b16 intake mani
ARP head studs
ACL bearings
ARP rod bolts
gsr water pump
timing belt
vtec solinoid
Ecu
bisimoto rods
bisimoto header
Really your critising cabinets? Yes I understand about the cams now, thank you I was unaware the proper storage for them was standing up I. Have stood them up now... feel free to not check this ever again if you don't care for it.
Standing up your cams is the least of your worrys. Better inspect the lobes before installing those
And your right, the cabinets look better than the valve cover
I would get Better cams for your build. The Stock B16 cams wont take you far.
Also get the VTEC conversion Head gasket. you will need to do some mods for the Dowel pins if you dont.
After market Intake Mani, with a Bigger throttle body. AND and GOOD header to go along with it. Then a TUNE
Haha i didnt do the valve cover, planning on polishing it or something. What cams would you recommend ive been checking out some b20v builds and noticing alot of people are using skunk2 pros, that and valvetrain parts like valvesprings and retainers. I was planning on a tune also thanks.
I was planning on a daily street car with some power, ive been looking at alot of differnt cams, and was wondering why it is hard to daily a car with aggresive idle? crower 402s are what ive been looking into the most right now any guidence would be greatly appeciated.
Was planning on bumping up compresstion before i thought about cams, was going to go with supertech 11:5:1 pistons and im still checking out rods. Im not sure if that what you ment by stock block or did you mean sleeving?
Completly forgot about this! Sold the B20 block, was going to go LSVTEC for a while ordered some parts. Before i recieved them i picked up a GSR block with arp head studs for $140. So now im working like crazy to order parts for this. Just a little update on the motor situation. Looking to fix all the body work new quarters and rust fixed then paint in the spring time. Ill update when i have some!
Got my intake mani painted wrinkle black, white valve cover... yes i know it says homo my brother thought he was funny. Time slip from an 1/8th mile track i ran at with my LS a few weeks ago, for sure need to improve on my driving! and the block stamp and a picture of the head studs installed! Might be a little while before more updates, had to pick up a wheel bearing this week and im in school soo cash flow is lowwww!
What do you guys think would be a safe number to rev out to with a micropolished and balanced rotating assembly? I know the R/S in Lsvtec is crappy, and shouldnt be revved to 9k, but what about this kind of set up?
GSR Block
ARP head studs
B16 head with stock valvetrain and GSR cams
Eagle "esp" rods
PR3 pistons
micropolished and balanced crank ect..
Not sure what else would help determine this kind of thing, any help would be awesome!
GSR Block
ARP head studs
Eagle "esp" rods
PR3 pistons
it should be the same for your cams
good luck with the project.
