valve cover nightmare
I used a paint stripper and then cleaned the VC. I tried spray painting the VC with a high temp spray paint but each time I tried I got the paint to bubble and wrinkle as it was drying. What am I doing wrong? The same thing happened when I tried to paint the plastic spark plug cover...
single stage spray paint..?
did u lightly sand it, or wipe it down with cleaner before hand..?
i use etching primer on any straight metal parts, before painting them. Not sure if the high temp needs to sprayed straight to metal or not, but thats how i like to do it.
You need to wetsand it a bit 400-600 grit.
You need to find high temp primer as well.
I used high temp primer on mine and then spray regular satin krylon and no issues with flaking or bubbling even under operating temperature.
ok, there is a few things that could have gone wrong.
did you neutralize the paint stripper after the paint started coming off ? (rinse with alot of water)
sanding grit depends on if your using primer surfacer. if using surfacer 120-180 grit if not 320-400.
clean with wax and grease remover. paint will seperate if surface is dirty with grease or sylicone type chemicals.
I cleaned it with water and brake cleaner. I am thinking the brake cleaner was probably a bad idea. I will try with the sandpaper and see how that goes, same for the plastic cover? I appreciate your advice.
