injectors leaking gas..HELP!
Old Apr 22, 2011 | 07:06 AM
90efboi's Avatar
Default injectors leaking gas..HELP!
ok so i took my intake manifold out cleaned it and put it back together
when i start the car or put it on ignition gas is spraying out the 3rd injector starting from the passenger side to the driver side. could it be bad injector or am i suppose to put alot of pressure down to bolt the fuel rail tight in with the injectors? has anyone had this problem before?
Old Apr 22, 2011 | 07:11 AM
Jockone's Avatar
Default Re: injectors leaking gas..HELP!
Did you replace the injector O rings?
Old Apr 22, 2011 | 07:12 AM
90efboi's Avatar
didnt kno i had to replace does, i thought the same ones will just work
Old Apr 22, 2011 | 07:13 AM
90efboi's Avatar
also its leaking from the top, where the filter in the injector is
Old Apr 22, 2011 | 04:18 PM
ascarberry's Avatar
orings as stated above will fix it!
Old Apr 23, 2011 | 08:28 AM
TheMightySi's Avatar
Yep O ring take one out of another injector and swap them out.
Old Apr 23, 2011 | 09:37 AM
B16-CRX's Avatar
NAPA sells the o ring kits. about $7 per injector
Old Apr 23, 2011 | 07:33 PM
stella88's Avatar
mine was leakin from the exuast port, injector was stuck open, I replaced it, re-set the ecu and no problems ever since!! Huge headach figuring it out!! You may have opened a can O' worms taking the intake off!
Here's my useless 2 cents!!
boostedteg4dr
Nov 30, 2013 01:17 PM
donut.
48
Mar 21, 2008 06:26 AM
lowboost civ
Apr 22, 2003 08:47 AM
trbob16a
Apr 17, 2003 12:41 PM
Perfectionist
Oct 23, 2002 01:41 PM
