CTR pistons in B16 VS CTR pistons in B18c. Hp differance?
Old Sep 28, 2002 | 09:13 PM
Halo's Avatar
Default CTR pistons in B16 VS CTR pistons in B18c. Hp differance?
Anybody know the hp difference between a B16 with ctr pistons VS a B18c with ctr pistons? Assuming everything else was equally stock? I am trying to justify the price between B16 $100-$200 and b18c shortblock $700-1000?
Old Sep 28, 2002 | 09:15 PM
Halo's Avatar
Default Re: CTR pistons in B16 VS CTR pistons in B18c. Hp differance? (Halo)
which is a better street/autox setup?
[Modified by Halo, 10:16 PM 9/28/2002]
Old Sep 28, 2002 | 11:00 PM
tonyxcom's Avatar
b18 handsdown. CTR pistons will also give you a higher compression ration in a B18 then a B16.
My JDM ITR pistons in my Type R block is slightly higher compression ratio (11.1 to 1) then a B16 block with CTR pistons - 10.8 - 1 I believe.
With CTR pistons in a B18 you get 12 to 1
Old Sep 28, 2002 | 11:07 PM
00CIVICwB18C1's Avatar
Well, I'm not exactly sure what the real HP difference is between the two, but stock motor vs. stock motor with those pistons yields a 10.8:1 compression ratio in the B16A (10.2:1 stock), and a 12:1 compression ratio in the B18c1 (10:1 stock). The b18c1 would be better for street/auto-x due to more torque. You'll also see the most HP gains out of the b18c1, at the cost of higher octane fuel (possibly needing higher than pump gas).
Old Sep 28, 2002 | 11:12 PM
GokuSSJ4's Avatar
Default Re: CTR pistons in B16 VS CTR pistons in B18c. Hp differance? (00CIVICwB18C1)
B18c1 with a nice gains of 12.1 CR
Old Jan 3, 2003 | 03:43 PM
advanracing62's Avatar
Default Re: CTR pistons in B16 VS CTR pistons in B18c. Hp differance? (Spoon1)
so a CTR piston in the B18C with a B16 head will yeild what compression? 12:1??? or lower? what about stock B16 pistons (PR3)????
Old Jan 3, 2003 | 03:58 PM
HXMan's Avatar
Default Re: CTR pistons in B16 VS CTR pistons in B18c. Hp differance? (advanracing62)
If using a GSR head compression will be up around 12:1 with CTR pistons. With a b16 head the compression should be the same as a stock CTR.
I dont know much about this stuff but from what I have heard GSR heads have smaller combustion chambers, resulting in higher compression.
Old Jan 3, 2003 | 04:36 PM
Default Re: CTR pistons in B16 VS CTR pistons in B18c. Hp differance? (HXMan)
if this is true then is it possible to weld up the combustion chambers?
JDM Lyfestyle
Jan 31, 2009 05:51 PM
rex89sir2
Apr 23, 2008 06:30 AM
chocolatecivic
Jun 23, 2006 06:23 PM
sikcrx80
13
Jun 11, 2003 12:46 AM
