Speedometer and Odometer NOT WORKING!!
Old Apr 21, 2011 | 08:21 PM
t-del28's Avatar
Post Speedometer and Odometer NOT WORKING!!
why is my 1997 del sol speedometer and odomter is not working????
the RPM and FUEL GAUGES IS WORKING FINE ALSO CEL did not showed.....
there's a thing that I took the VSS out from gsr tranny and to put new tranny fluid in it....
i did cleaned the connector for corrosion and tested on orange wire lead and its read at 9V...is it suppose to be under 5V or what?
WHAT MIGHT BE THE PROBLEM???
Old Apr 21, 2011 | 10:21 PM
314househead's Avatar
Default Re: Speedometer and Odometer NOT WORKING!!
http://www.tegger.com/hondafaq/tsb/civic/x99-029e.pdf
maybe?
Old Apr 22, 2011 | 10:31 AM
t-del28's Avatar
Post Re: Speedometer and Odometer NOT WORKING!!
Originally Posted by 314househead
does it work for you before?
does anybody having problems with VSS before?? Please need tips and help!!!
Old Apr 22, 2011 | 07:00 PM
t-del28's Avatar
bump....
Old Apr 23, 2011 | 11:55 AM
JDM'dinMD's Avatar
I've been encountering the same problem kind of my rpms will drop like I let off the gas, but I didnt. I havent fixed this problem yet but I replaced the VSS an that wasnt the problem. I think my speedo wraped around the whole way so I will have to take it out an see if I can unwhined it or something. Hope it didnt burn up the motor in there or something
Old Apr 23, 2011 | 09:53 PM
93Eh6pWr's Avatar
Ive had 2 speedo's (the gauges themselves) crap out on me.
Thankfully, my GPS tells me how fast im going lol.
Old Apr 23, 2011 | 10:23 PM
Slow HX's Avatar
Take the cluster out and see if the four screws that the hold the gauge to the body have come lose. Those screws also give the connection to the gauge. Hope that helps.
Old Apr 24, 2011 | 07:31 AM
EJeff8's Avatar
Mine did this and it was a wire issue in between the VSS and the Speed/odometer. Last owner swapped wires (makes me think he cut them to lower miles on the car -_-)
Old Apr 24, 2011 | 09:21 AM
97dssi's Avatar
We figured it out. It was not VSS and wiring. Everything is working well. So we took the VSS out of tranny and look into the hole. We found out that its missing speedo gear in the transmission…
Old Apr 24, 2011 | 02:58 PM
hmonguy918's Avatar
good that you figure yours out.. mines broken on my em1 too.. doin the same thing... replace the speed sensor replace the fuse.. still broken
Old Apr 24, 2011 | 06:33 PM
Project Dad's Avatar
Having same non working issue. I put a '98 d16y7 in my '96 HX, but running a '96 ex 5 speed. The VSS installed was already in the tranny. dunno if broken or just the wrong one for the '98 y7 ecu
Old Apr 24, 2011 | 07:31 PM
97dssi's Avatar
it easy to find out if your VSS working or not.
1. take the VSS out but leave the plug in
2. start the car
3. have someone watch your speedometer while you spin the gear with your hand.
4. If speedometer moving so that means its working good.
Old Apr 25, 2011 | 12:36 PM
2. start the car
thats a good check to do, but I can drive the car to get the same results.
Old Apr 25, 2011 | 12:49 PM
97dssi's Avatar
yea i know but we found out that its missing speedo gear in the transmission. so we will have to take transmission out and put speedo gear back on the differential... bet it will pain in the *** while doing this.
Old Apr 25, 2011 | 01:05 PM
makes me wonder why they would take it out. unless it was rebuild and forgot to put the gear back in
Old Apr 25, 2011 | 01:10 PM
97dssi's Avatar
yea it was rebuild transmission.
t-del28
Apr 23, 2011 06:40 AM
blacc_ej1
Oct 14, 2009 01:49 AM
strykr89
Sep 15, 2008 08:03 PM
adobospoon
23
Dec 24, 2006 08:56 PM
Staats0778
Jan 12, 2005 01:30 PM
