Brake swap
Which brakes would be an upgrade from the brakes that come w/ a 94 Civic Si. I have ABS 4-wheel disk brakes and want brakes from another Honda/Acura that would be better.
Always the awesome ITR brakes with the 5-lug as well.
But I do not know how the abs system would do with the bigger brakes.
There may be issues there...I have never met anybody who has upgraded
with an abs system.
Good Luck.
with an abs system.
Good Luck.
you can go either gsr or itr 5 lug..but a good set of rotors and brake pads will probaly give you the same performance....although 5 lug def looks cooler and you can tell everybody it's from a type R
