Suspension & Brakes Theory, alignment, spring rates....
What Rear OEM sway bar will bolt up to a 98 civic ex?
Old Apr 21, 2011 | 05:53 PM
namewasdallas's Avatar
Default What Rear OEM sway bar will bolt up to a 98 civic ex?
I'm looking go to my local junk yard or pick up on here a cheap oem Rear sway bar for my 98 civic ex, I know there's a oem rear sway bar off maybe a 96-01 acura integra LS or maybe im wrong that's way im posting this so i can find the correct sway bar that will mount up.
Thanks.
Old Apr 21, 2011 | 07:17 PM
98civdx's Avatar
Master Detailer
Default Re: What Rear OEM sway bar will bolt up to a 98 civic ex?
The Integra bar will work.
I am not totaly positve if you can use the intgera bracket. (bar to subframe) So I would say get one for a 99-00 SI.
Keep the DC sway bar bushings, or replace. Your choice. Also, use the D-Bracket.
You'll need to get Bushings for the ends of the sway bar. (Endlink side) Reason is the hole is to large to use OEM/aftermarket endlinks. Function7 sells them for like $20
Next is endlinks. You will either need to use 99-00 SI, or aftermarket adjustable or fixed.
92-00 civic will work, as will 94-01 integra.
Old Apr 21, 2011 | 07:23 PM
PreyStayShun's Avatar
EX arms already have mounting holes for a swaybar, so pickup a 14mm bar from the teggy and some 99-00 SI endlinks and call it a day!
Edit: my bad on the post reprint, 98 got there first!
mach0
24
Mar 19, 2010 09:12 AM
rexman2002
Suspension & Brakes
Jul 6, 2009 11:12 AM
amej8
Jun 17, 2008 06:16 AM
Turbo_y8
Apr 26, 2007 03:26 PM
PARADOX_sf
Suspension & Brakes
19
Jan 10, 2007 01:40 PM
