Ej8...Which rear sway bar?
I have an ej8 that I am starting to work on. Its going to be a dd. I was wondering what rear sway bar can I use without having to get a subframe brace. I dont want anything crazy, as I mentioned it will be a swapped dd and will not be raced or auto x'd. Maybe some occasional spirted driving but nothing serious.
I did not have soo much success using the search feature. Maybe I typed something in wrong. But I'm in for some hopefully decent answers.
Re: Ej8...Which rear sway bar?
Thanks for the information. I would be looking for an oem bar. I was wondering if it was anything like changing the oem ls on my dc for and itr and tear up my subframe. Thanks guys.
318 Curves, 11 miles
In that case, you should be able to use the 99-00 Si bar with no tearout problems. I believe the Si has the same subframe as the EJ8.
Crazy Honda Guy
I think people have forgotten that to use an oem Si bar, you need new LCA's in order to mount end links on the sway bar, unless your car already has provisions for them?
You can use the sway bar from a Si, integra, or the del sol with b16a2.
I have a Si rear sway on my ex, best upgrade for the money on a dd.
Crazy Honda Guy
where's the best/cheapest place to get an SI sway bar and end links? i was kind of looking into doing something small with no subframe brace for now too.
The title said ej8. Its a coupe not the 4door model. Thanks for your input as well as everyone elses..Now I need to find an EM1 rear sway with endlinks.
namewasdallas
Suspension & Brakes
04-21-2011 07:23 PM
amej8
06-17-2008 06:16 AM
