vss
Stand in front of your car with the hood up, look at where the TB is, look slightly to the left, then look down directly above the differential housing is, it will be to the left of that.
To remove it you need to remove the airbox and thermostat housing first. Then you can remove 2 of the shifter cable bracket bolts and loosen the third to swing it out of the way. Then you can remove the two 10mm bolts that hold the VSS. Make sure when you remove it you don't lose the little driveshaft.
