Power Window doesn't work with door open?
Old Apr 21, 2011 | 04:09 PM
DAP97SI's Avatar
Default Power Window doesn't work with door open?
I noticed that my power windows or locks don't work when the drivers door is open, is this normal? I have a 97 civic hatch with the power window conversion. They work fine when the door is closed but don't work at all when it is open. Just trying to find out if this is normal or if I have a problem that I need to fix.
Old Apr 21, 2011 | 05:34 PM
hyperblu's Avatar
Default Re: Power Window doesn't work with door open?
Depends on how the pw were installed... We can't tell you because we didnt install it. My guess would be the way you wired it, the power is cut off when the ajar door sensor is activated...
Old Apr 21, 2011 | 06:28 PM
canadaek's Avatar
or the wire's in your floor harness are starting to break . look on the inside of the plug that goes into the door . the harness i got had 14 broken wire's out of like 17 .
Old Apr 21, 2011 | 06:32 PM
Former User's Avatar
The wire harness that runs between the door and cabin is the prime suspect.
Old Apr 21, 2011 | 06:33 PM
s13hero's Avatar
I have a 95 EG hatch I installed pw and I can roll down the windows with the door open
Old Apr 22, 2011 | 05:28 AM
DAP97SI's Avatar
ok, I will have to inspect the wire harness.
Chance EG
Jan 11, 2017 01:52 PM
Kyle700
Dec 10, 2014 11:32 AM
Rayz_Si
Apr 21, 2008 06:17 PM
Got-VTEC
Feb 23, 2007 10:47 AM
