91 Civic slow battery drain.
Old Apr 21, 2011 | 01:49 PM
hell_sol's Avatar
Default 91 Civic slow battery drain.
Hi guys, I've got a slow drain on one of my fuses so i've been trying to figure out where the short circuit is.
It's on a 15a or 20a fuse that runs the horn and the stop lights, so i unplugged the horn and every bulb on the tail lights, but still haven't been able to locate the slow drain.
I looked for wiring diagrams on google, but couldn't find anything.
If someone could tell me what other components are ran from that fuse, that would help greatly.
Any help would be appreciated, thanks.
Old Apr 21, 2011 | 03:54 PM
99SiStyle's Avatar
Default Re: 91 Civic slow battery drain.
ZHow did you get to the conclusion it was that one? I have a slow drain of my own.
Old Apr 21, 2011 | 03:58 PM
XJorXdanX's Avatar
sure it's a fuse or wiring? could just be a bad alternator.
then again if you have speaker wires to an amp or something they could be grounding out also.
Old Apr 21, 2011 | 03:59 PM
hell_sol's Avatar
I tested the amps coming out of the fuse port with a multi-tool and it was pulling .7 amps with the key off.
Old Apr 21, 2011 | 06:46 PM
hell_sol's Avatar
The leak is at a continuous .7 amps so i ruled out bumping wires. The car doesn't have a radio either. Is there anything else that runs on the "Horn Stop" fuse?
Juju2010
Apr 14, 2015 11:15 AM
ludecrasy87
Honda Civic (2001 - 2005)
Mar 17, 2015 06:07 PM
bank2me
Feb 20, 2011 04:58 PM
merch1
Mar 6, 2005 11:07 AM
