H23A blue top?
Old Apr 21, 2011 | 12:44 PM
REX111's Avatar
Default H23A blue top?
anybody know the torque specs for the rod bolts?
Old Apr 21, 2011 | 12:53 PM
kris95dx's Avatar
Default Re: H23A blue top?
1- 35ft lbs
2- 58ft lbs
3 80ft lbs
unless there's something special about it?
Old Apr 21, 2011 | 01:14 PM
Mr. EG's Avatar
Originally Posted by kris95dx
1- 35ft lbs
2- 58ft lbs
3 80ft lbs
He didn't say head bolts you idiot. The correct torque spec for the rod bolts is 34 Ft lbs.
Old Apr 21, 2011 | 01:31 PM
kris95dx's Avatar
yep, reading comprehension fail....thanks eg
Old Apr 26, 2011 | 07:49 AM
REX111's Avatar
This motor dosen't have studs on the rod with a nut over the cap, it has 12point bolt like the s2000.
Old Apr 26, 2011 | 08:55 AM
95skunkedgsr's Avatar
google?
Old Apr 26, 2011 | 09:57 AM
REX111's Avatar
looked everywhere. Google. other car sites. even had a friend call a UK dealership with no luck. As far as I know this is the first motor that had bolts on the rods instead of studs/nuts like the h22. So most of the torque specs found are for the stud/nut set up not the bolts.
leem23vtec
Jul 18, 2010 06:58 PM
SrT4u2nV
Jul 19, 2006 04:33 PM
CA6VTEC
Dec 12, 2005 10:17 PM
H22coupe
Apr 30, 2004 05:24 PM
S13 slide
Jan 8, 2002 09:29 AM
