d16z6 to 3 stage d15b
Old Apr 21, 2011 | 11:59 AM
jestin91's Avatar
Icon2 d16z6 to 3 stage d15b
can i use d16z6 parts on a jdm 3stage vtec timong belt water pump ect.......
and a auto ecu will work on a 5speed
Old Apr 21, 2011 | 12:17 PM
vartok's Avatar
Default Re: d16z6 to 3 stage d15b
cant speak for the parts, but the ecu should work, you will just get a CEL.
Old Apr 21, 2011 | 12:24 PM
jestin91's Avatar
ok ok cuz i cant seem to find a 5 spped one but alot if autos
Old Apr 21, 2011 | 01:06 PM
djslim23's Avatar
the 5spd ecu will run you $200 from hmotors...and no you cannot use the auto ecu on 5spd, I forget why exactly, something about being in park. But if it worked, nobody would bother finding the rare 5spd ecu. Water pump and timing belt should work.
Old Apr 21, 2011 | 01:15 PM
grumblemarc's Avatar
The Grumpiest
Why are you getting a 3-stage VTEC engine.? It's not a direct replacement nor will it make you any faster.
Is this you? Are you creating new accounts?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/has-anyone-ever-donw-3-stage-vtec-swap-upgradesc-something-no-outcome-2921478/
Old Apr 21, 2011 | 03:39 PM
B18CivicEJ8's Avatar
https://honda-tech.com/forums/showthread.php?t=2921478
grumblemarc, although I agree with you, it seems like you're wasting your breath cause OP seems determined to go 3 stage vtec. In previous posts, it has been said that finding a manual ecu for this setup is going to be darn near impossible, but yet the OP persists. Sometimes you have to let people fail in order for them to learn the lesson you were trying to help them learn without pain.
jestin, once again, you will have to get the correct ecu in order for the 3 stage vtec to work properly. An auto ECU will not work on a manual setup. Good luck finding a manual 3 stage vtec ecu. People have already told you that they are rare. Rare, in case you don't know, means hard to find.
Old Apr 21, 2011 | 09:39 PM
jestin91's Avatar
i just want the motor for the great mpgs
Old Apr 21, 2011 | 09:49 PM
jestin91's Avatar
yea that me i hit my head realy bad the outher day and i forgot all my passwords had make new email and h-t
Old Apr 22, 2011 | 03:59 AM
The Grumpiest
Good luck with that.
Old Apr 22, 2011 | 04:39 AM
djslim23's Avatar
It does get good mpgs.....mine gets 40+ city driving. I got below 30mpg city driving in the same car with my y7. But the y7 was old and beat up, my d15b was fresh from japan. There are many more factors that affect mileage than the motor. If you're looking to save money, look elsewhere. OP, the reason I got my d15b is because I couldn't afford a B when my y7 kicked the bucket, and I needed the cheapest swap from hmotors that I'm hoping will last me a long time. The mileage is a nice perk, but 3/4 the time I drive hitting vtec and then I only get about 30mpg.
Old Apr 22, 2011 | 04:55 AM
dem0nk1d's Avatar
The auto ecu will work in a manual car. You just have to remove a resistor or what not, and bam you have it working CORRECTLY for the manual.
https://honda-tech.com/forums/tech-misc-15/obd1-auto-ecu-manual-conversion-pics-858920/
http://www.pfmgi.org
Old Apr 22, 2011 | 05:21 AM
djslim23's Avatar
^This is OBD2, not OBD1. Oops, huh? DISOWNED
Old Apr 22, 2011 | 05:42 AM
dem0nk1d's Avatar
why would you run obd2, that's the lamest thing i've ever heard. no tuning options, and why didn't you state obd2. LOL!
you can convert one obd2 board to manual that i know of....
OBD2 P5 MAuto Manual = Converting a 97-01 H22A Prelude PCM from auto to manual
http://wikitest.pgmfi.org/twiki/bin/...2P5MAutoManual
Old Apr 22, 2011 | 05:56 AM
djslim23's Avatar
LOL - 3 stages are ONLY obd2.
Old Apr 22, 2011 | 07:06 AM
jestin91's Avatar
yea i wanted to do the p28 butttt i can support the the 3 satge
Old Apr 22, 2011 | 08:25 AM
dem0nk1d's Avatar
djslim - the 3 stage vtec also came out in 95 so this could be obd1 as well. as you know 95 was the last year for obd1. so really in theory a obd1 ecu exist with the wiring circuit for the 3 stage.
http://en.wikipedia.org/wiki/3-stage_VTEC
Old Apr 22, 2011 | 08:42 AM
jestin91's Avatar
some were is this world
Old Apr 22, 2011 | 08:44 AM
dem0nk1d's Avatar
i think your best bet is to switch over to the AEM UNIT, and just program the unit for the 3rd stage vtec. I don't think it's possible with the stock units. Unless this uber rare 95 ecu exist.
Old Apr 23, 2011 | 02:20 PM
djslim23's Avatar
There are no OBDI 3-stage engines. I think that might say 95 cause Japan's production was a year ahead, I believe. I'm not trying to be a *****, I just feel bad for a lot of the younger people who stumble upon a 3-stage engine and think they can get around finding the p2j ecu. The truth is a B swap would be less fuss, roughly a few hundred more dollars, and much more power. I'm gonna need to build and boost it sometime soon or I'm gonna go crazy.
Old Apr 23, 2011 | 03:20 PM
tony_2018's Avatar
Fish Twig
Ecu will work, just need to worry about iacv. Motor was built for efficiency plus some pep as well.
Old Apr 25, 2011 | 02:22 PM
dem0nk1d's Avatar
Stage 3 vtec on a obd1 chipped ECU.
So I think it’s possible to program the 3 stage vtec off of a Honda obd1 ecu. I think you could either trigger the solenoid off the ac switch or enable the secondary throttle body butterflies like the p72 gsr computer uses. Well it’s a thought.
Old Apr 28, 2011 | 04:50 PM
TaffetaEj6's Avatar
so you hit your head and forgot your info and started a new account...w/ this account you want to swap a z6 for a jdm d15b, but w/ your other account you have a y8 and wanna swap for a d15b???? Your making several useless threads about the same topic...IMO you are so full of ****. You have no car, your >15 yrs old, you like hondas, and somehow stumbled onto h-t and continue making an *** out of yourself. Good job buddy!
Zach Barrette
Sep 14, 2017 02:59 AM
That Guy 32
Jul 6, 2007 07:44 AM
sam385
12
Sep 3, 2005 08:31 PM
del_sol
Mar 26, 2003 07:21 PM
