Car theft solutions... got any?
Old Apr 20, 2011 | 05:57 PM
efb16a's Avatar
Default Car theft solutions... got any?
Hey, I'm looking for any tips or suggestions to keep my car from getting stolen. An alarm is in the works, I have a removable steering wheel, I take out my stereo faceplate religiously, and keep my car completely empty, yet it gets broken into once a week! they just jostle all my stuff around and leave my door half open. I'm afraid my precious b-swap will get stolen... so far i've come up with these;
cut my shifter and thread it, then drill a small hole for a padlock so you can't thread anything else on
Round all nuts and bolts on my motor mounts
I know theres other threads on this, but a lot of the other ideas mentioned are easily bypassable, any help would be awesome!!
Old Apr 20, 2011 | 05:58 PM
cdh/ej1's Avatar
Default Re: Car theft solutions... got any?
Get a kill switch installed or kill switches lol
Old Apr 21, 2011 | 07:48 AM
bankonyourself's Avatar
Get some Kill Switches installed ASAP while waiting on the alarm. The more layers the better. That's not good if they are breaking to your vehicle right now. Perhaps a car cover with a good lock to cover it @ night?
Old Apr 21, 2011 | 12:30 PM
TunerN00b's Avatar
Just spend the time and fix the theft issue once and for all.
Old Apr 21, 2011 | 02:18 PM
djkurious's Avatar
Get the alarm and do a stealth install
Old Apr 21, 2011 | 04:38 PM
0c00l's Avatar
I have kept quiet about this subject until now because I know no matter how I say this there will be someone who will say "If they want it bad enough, they'll get" and for the most part there right. However, I have always had a simple alarm with proximity sensor on every car I have owned, no back up battery, no lo-jack.
I have had several attempts on a few of my civic's but not one them were ever compromised. The only thing I would add now is an alarm with paging keypad like the 5900's or better. Pick your brand DEI owns most of them anyway, but with a paging system and proximity sensor it's very difficult to get past without you(the owner) knowing about it.
Old Apr 21, 2011 | 04:41 PM
0c00l's Avatar
Although this would be my first, no second, ok second choice. I just love the AR. Why can't they make this fit in my pocket?
Old Apr 21, 2011 | 04:46 PM
2000em1boycivic's Avatar
dont show it off and it will never get stolen
Old Apr 21, 2011 | 07:27 PM
efb16a's Avatar
I have a .44 magnum, but it doesn't work while I'm sleeping... The killswitch is going to be included in the alarm install, (I install commercial security alarms, so it will be stealth and secure as a ****) so if you think that will work thats great. and I also got an idea from an old car guy i know. He has a 67 chevelle, and he made a pretty nice kill switch for it. he took a 1/4 thick steel plate and welded a box out of it, then ran 12 wires into and back out of it, one of which being the ignition wire, the rest being grounded with an uncommon fuse hidden elsewhere, so if you attempt to bypass and cross wires, it will blow the fuse. he then put 10 switches in series in a random pattern on the box, then welded it shut and hid it behind the glovebox (it wasn't driven very often, I'd put mine elsewhere). Sound like a winner, or is this old dude crazy?
Old Apr 22, 2011 | 06:38 AM
eddie422's Avatar
when i had my DA i would always take my fuel pump relay out and if they ever did get that far as too try to drive away in it they wouldnt be able to start it trust me they r not gonna spend they whole time trying to figure out why the car wont start
Old Apr 22, 2011 | 06:43 AM
OGv2siik's Avatar
build a garage, install motion sensors, buy an AK, post up on the daily. /thread
Old Apr 28, 2011 | 09:50 PM
Dyl@n's Avatar
put a kill switch on the fuel pump and hide it good.. it worked for me
i always unplug my distributor to
Old Apr 29, 2011 | 03:54 PM
NVturbo's Avatar
O.G. triple O.G.
^^^ unplugging the distributor time after time can be a hassle...as well as cause damage to the plugs themselves.
Old May 3, 2011 | 06:42 PM
ElementzofR's Avatar
detacheable steering wheel, kill switch(s), alarm, etc. its all about layers
Old May 3, 2011 | 08:14 PM
denieone's Avatar
a properly install alarm and layers..............6 months ago they tried stealing my baby, 10 years with out a problem............. but my 10 year old clifford and that stupid autolock, oh and a kill switch saved my car.
Old May 7, 2011 | 11:37 AM
DARKB20's Avatar
a decent stealth install alarm, gps system combo with back up batteries. https://www.mobileiqonline.ca/Templa...LoginPage.aspx
lets you sleep at night..
Old May 9, 2011 | 03:02 PM
rko goonz 8's Avatar
thanks for the info guys have a 08 civic si coupe and am doing work to it now, don't want things like this to happen
Old May 9, 2011 | 03:13 PM
nsxxtreme's Avatar
You can install a relay on the power wire to the distributor and then either hook it to the alarm or remote switch. If you splice it far enough back you can retain the stock harness and it looks completely stock.
Old May 9, 2011 | 07:11 PM
blurrx808's Avatar
killswitch, one under the dash and one in the engine bay. should do the trick.
Old May 11, 2011 | 08:12 AM
NVturbo's Avatar
O.G. triple O.G.
Here is a link to my DIY thread that WORKS:
http://www.carolinahondas.com/instal...ar-thefts.html
Old May 11, 2011 | 08:37 AM
0c00l's Avatar
http://www.amazon.com/NRG-Innovation.../dp/B000ED5I5A
Old May 15, 2011 | 04:38 PM
momonimill's Avatar
give your car a yellow boot lol
Old May 15, 2011 | 04:50 PM
Chak's Avatar
Silent warning system/ GPS & AR-15
Old May 15, 2011 | 04:56 PM
NA James's Avatar
Hook up a wire from your house to the car and attach the power and ground to something metal. As soon as they touch it they will be electicuted. Lol.....
Old Jun 15, 2011 | 09:25 AM
thegame7's Avatar
I'll be buying a yellow boot to put on my car. One would suffice, a thief would see that and immediately not want to deal with it. You can even get ones where if they try to drive off with your car, spikes will puncture the tire and they won't get far. That is only if you don't have a fuel pump kill switch OR an alarm. Here is how it would go: they try to break in, alarm goes off, they get in and disable the alarm and now they can't figure out why the car won't start because you've hidden a kill switch somewhere. Well hell, it also has a boot so they'll probably take what they can from the interior and jet, unless you've already got to them with a gun to their head in which case they wouldn't have got that far. BOOT IT!
