OBD2b to OBD1 Engine swap problem
I have a HOnda Oddy 97's (originally with F22B6 USDM) with the F22B JDM swap. I finally found the socket near the oil pump where the original TDC/CKP sensor was connected. I believe my car now has an OBD1 dizzy (2 plugs/ 9 pins total). I found that there is a matching four pin plug connected to the original socket. So I did a continuity test btw the 9 pins in the dizzy and the 4 pins on that plug and found that all 4 wires (two TDC and 2 CKP wires) are connected to a single pin on the OBD1 dizzy connector. They're all connected to the ignition input signal (yel/Gr) pin (also called ICM ingnitor). Is the correct?
Now my guess is that's because the OBD2 ECU expects a some sort of signal from the red/green (TDC) and blue/white (CKP) so the swaper connected them to the ICM ignitor wire on the dizzy. I noticed if I unplug that plug the car will churn but not start. However, are there not special wires on the dizzy for each of the 4 wires in the crank?
I tried to run the car with a chipped p75 OBD1 ECU (which runs my car fine) connected with an OBD2b to OBD1 harness convertor and it runs fine.
But when I connect it to the original OBD2 ecu, the car throws misfire codes for all 4 cyl and idles horribly (esp when hot). Cold start is no problem until about 7 km when the hot engine start to stall at stop signals and is hard to keep from stalling even on if I leave the car on PARK. Once the hot car restarts it's on a very low bogged down idle (with a little shake) until I rev it. If I let it cool down, then it restarts fine.
So my question is: What is going on?
should I do the bypass trick (at the ECU) to solve the misfires with the OBD2 ecu? Could the misfires also lead to low mileage? Btw, my low mileage is on both ecus. I can't read the misfire (if any) with OBD1 since there's not connector to read codes in the car (which is obd2 to start with).
I was told that until I replace the sensor in the crank, my misfire problem will not be solved. e already got all the part to make this engine OBD2 compliant (oil pump houseing, spoket, crankshaft spoket, TDC/CKP sensor).
The second question: If i were to put the sensor back at the oil pump, and connect the socket to the sensor, would I need to replace the dizzy (to the original OBD2b one) or could I just run the car with the same OBD1 dizzy? Reason I ask is that I'm planning on doing this mod this summer and want to know if i'd run into any probs.
Thanks in advance for any help
4crx4me
Nov 23, 2017 12:22 PM
h22HatchEG
Apr 22, 2006 10:39 AM
