Multiple port sandwich plate.
Does anyone sell a block adapter with two -10 for a oil cooler and a -6 for b20/v? I dont want a remote filter setup.
I am running rs machines pistons and I didnt know you need to notch them for squirters. Well I already had the bottom end balanced and put together when I found out. I was hesitant but since ls/v doesnt have them either I just plugged them.
I use the Mfactory oil cooler with a sandwich plate. The plate itself has 3 ports, two on the bottom and one on the side. I think it's a Blox?? Can't remember...had it forever.
I see 2 options:
1.) Tee out the oil cooler return and filter it to the head....or use a remote oil filter on the return line.
2.) Use an oil cooler sandwich plate and a GE sandwich plate.
I emailed mf and they said only 2, will check out bloxs. Invtec that will be last resort, trying to keep it as clean and simple as possible.
It won't work, as the adaptor supplied with the oil cooler kit is different.
However, what you can do is purchase/install an additional sandwich plate "between" the block and the oil cooler adaptor. This will end up giving you 5 x Ports to use.
Pompiuses
Sep 3, 2010 09:29 AM
DavidR
Feb 13, 2006 04:03 PM
FlyZlow
16
Aug 2, 2005 07:50 AM
ActiveAero
Jan 24, 2005 05:34 AM
