misc 88-91 civic hatch and sedan parts si stuff and a6 parts
Old Apr 19, 2011 | 08:46 PM
Ghett0_ed's Avatar
Icon5 misc 88-91 civic hatch and sedan parts si stuff and a6 parts
Have a lot of parts laying around that I'm trying to get rid of all items are obo
Complete a6 intake manifold with throttle body injectors all plugs and pigtails to plugs...$100
Two resister box's both work great...$15 each
Pm6 ecu from 88-91 civic si..$40
Will bundle the manifold one resister box and ecu for $135. Everything you need minus distributor to do a multi point injector swap in your non si ef.
2 under dash fuse box's work perfect...$20 each
Si complete ignition with ignition switch and key..$20
88-89 matrix m clear corners brand new in box never used..$20
88-89 matrix m clear bumper lights brand new in box never used..$20
Both sets together..$30
Ef sedan hood maroon in color very good condition bought it thinking it was for hatch but its to long..$60 (WILL NOT FIT CRX OR HATCH, SEDAN ONLY)
SI rear sway bar bolted to si lcas..both lcas and sway bar..$40
90-91 headlights one missing the adjustment screw can swoop one from a junkyard no problem...$30
89 driver side door panel with speaker cover I think its from a dx since the cloth insert is grey not black..$15
Pm7 ecu from a jdm zc ef..$50
Ef usdm oem optional eq lower console black bare( no ashtray eq or lighter)..$75 Found out that this is for sedan . May fit hatch with some modification to the shifter cover.
Complete a6 valve train, springs and retainers and cam...cam has some surface rust just needs to be machined..$20
That's all I can think of right now will probably add more later. Will trade for other ef ed parts just let me know what you have.
Old Apr 24, 2011 | 06:58 PM
ZCeddie586's Avatar
Default Re: misc 88-91 civic hatch and sedan parts si stuff and a6 parts
Hit me back man I could use the bundle ur offering with the pm7 for the sohc zc I put in my ef.
Old Apr 29, 2011 | 10:29 AM
Ghett0_ed's Avatar
Pm'd
Old May 8, 2011 | 05:59 PM
Ghett0_ed's Avatar
Bump
Old May 9, 2011 | 08:40 PM
GT35R_EF's Avatar
Make mine whatever you want
Are the 90-91 headlights for a sedan or hatchback?
Old May 9, 2011 | 09:21 PM
Eran's Avatar
HT White Ops
Do you have any tilt columns?
Old May 9, 2011 | 09:29 PM
dizzlebB's Avatar
bump^^^^
thanks for the sway bar!!!
and as far as paint if you buy the the materials ill hook it up with labor just to help out a fellow ef man lol
Old May 13, 2011 | 10:07 AM
Ghett0_ed's Avatar
Headlights are for hatchback
no tilt columns
And thanks Daniel ill be hitting u up shortly
Old Jun 4, 2011 | 07:44 PM
Ghett0_ed's Avatar
Make offers need it all gone
classciv
Sep 3, 2007 06:05 AM
powerslide360
May 25, 2005 06:00 PM
kid-honda
Dec 9, 2003 08:21 AM
