b18c CEL code p1337 & p1457??????
Old Apr 19, 2011 | 05:48 AM
gsr-t9303's Avatar
Default b18c CEL code p1337 & p1457??????
hey guys i have a 2000 teg with a jdm b18c swap obd2 and these freaking codes are poping up. does anybody know what they are?
any help is great.
Old Apr 19, 2011 | 11:20 AM
53JDMDC2's Avatar
Default Re: b18c CEL code p1337 & p1457??????
the 1337 is cause you dont have a crank sensor any more with the jdm engine.
google CKF trick it should help.
on the CKF trick dont use the blue connectors he shows. use red ones they r for small wire. Dont cut any wires. and depinning i dont think will work cause the cpu needs to see a signal. as for 1457 i have to check what that code is.
Old Apr 19, 2011 | 11:29 AM
53JDMDC2's Avatar
1457 is a vaccum leak code. check all your vaccum lines, gas cap, and the canister.
Old Apr 19, 2011 | 06:36 PM
gsr-t9303's Avatar
thanks 53JDMDC2 ima get on that asap. if i swap over a usdm oil pump can i just mount the sensor and will it work on my b18c???
Old Apr 20, 2011 | 10:58 AM
gsr-t9303's Avatar
can any 1 help please i need to figure this out quick sense this is my only car.
if i swap the usdm gsr oil pump will the ckf sensor mount and work on my jdm b18c?
Old Apr 20, 2011 | 08:22 PM
53JDMDC2's Avatar
if you put a usdm oil pump you will have the sensor and it will get rid of the code p1337. as for p1457 you need to find the vaccum leak.
Old Oct 2, 2011 | 03:47 PM
siboost93's Avatar
quick question, i have a 96 civic ex with the 1337 code, will that make the car wanna stall and rpm gauge jump all over the place when tryin to drive it?
Old Oct 2, 2011 | 05:14 PM
fcm's Avatar
fcm
Old Fart
http://www.ff-squad.com/technet/ckftrick.htm 94
Frany
Sep 23, 2015 05:33 PM
gsr-t9303
Mar 30, 2011 09:45 PM
JAMN J
Sep 11, 2007 03:56 PM
EKen9
Jul 6, 2002 04:20 AM
CivicEx95
May 9, 2002 03:22 PM
