Can't adjust ignition timing any further
Old Apr 18, 2011 | 03:17 PM
fernando.'s Avatar
Default Can't adjust ignition timing any further
I've got a B20b that I convered to OBD1 with the intake manifold, dizzy, ect all from the old LS motor.
I put the gun on the crank and the red dot lines up with the mark on the timing cover a 5 degrees BTC, I tried to move the dizzy back and I can only get it to around ~ 12 degrees BTC before the dizzy maxes out on the sliders.
I changed the timing belt and water pump on the motor and made sure to double and triple check the timing when I did it, everything lines up and nothing is off.
Old Apr 18, 2011 | 10:12 PM
mark@silbernage's Avatar
Default Re: Can't adjust ignition timing any further
Double-check the part number (how many teeth) on the water pump?
Old Apr 18, 2011 | 11:10 PM
dntnedvtec's Avatar
I wonder if you set the car to TDC off the oil pump, not the crank mark........Just asking.
Old Apr 19, 2011 | 08:09 AM
fernando.'s Avatar
No everything is fine, I found this out:
Originally Posted by inspyral
If you use a non-adjustable light, then you use the red/brown markings on the crank pulley to set timing since it's basically direct-read. If you're using an adjustable light you're supposed to use the white mark since the light will delay its pulses to line up with the white mark based on how much timing advance/retard you dial-in to it. If you're still confused about it, just set your light to 0 and use the marks on the crank.
And figured out I was doing it wrong since my gun is adjustable.
Old Apr 19, 2011 | 10:02 AM
jvz555's Avatar
Make sure you have the the gun set on the first spark plug, not 2-4.
royalfelix
Jan 26, 2009 08:08 PM
baphomet
May 31, 2005 12:52 PM
jdurston
Jun 9, 2004 05:30 AM
Lei Siew Long
Mar 31, 2004 12:43 PM
slowd16z6
Mar 13, 2004 02:20 PM
