Gsr turbo - cracked ringlands, what are my options?
Old Apr 18, 2011 | 03:13 PM
REDEM1FTW's Avatar
Icon3 Gsr turbo - cracked ringlands, what are my options?
I started seeing smoke coming from the nipple on the valve cover today and just did a compression test on my gsr turbo and the results were not pretty. The compression on cyl 1was 90psi while the rest are at 180. My problem is I am stuck on what to do from here, I cant make my mind up on what to do next. The car is my daily driver and still drives ok (for the time being at least). I need the best bang for my buck and im a college kid on a budget. Should I A) Rebuild w/ GSR pistons B) Buy LS and do Ls/Vtec. I was told it wouldnt be worth it to rebuild the gsr bc it would involve a lot more than just slapping pistons in. Im stuck, so any opinions or previous similar experiences would we great. Thanks a lot.
- Josh
Old Apr 18, 2011 | 03:26 PM
racebum's Avatar
Default Re: Gsr turbo - cracked ringlands, what are my options?
fix problem #1 first and that's why you cracked a ringland
my guess is:
1. too much power on the stock bottom end
2. too much timing in the tune
address that before you continue on
also, unless you used a boreascope are you sure it's a ringland? exhaust valves are another extremely common cause of this when then frag
Old Apr 18, 2011 | 04:11 PM
LightningTeg's Avatar
Community Builder
Power doesnt crack ringlands, detonation does
Old Apr 18, 2011 | 04:14 PM
racebum's Avatar
that's actually a good point, if the engine is tuned right too much power will break a rod or fastener, not blow a hole in ****
Old Apr 18, 2011 | 08:13 PM
REDEM1FTW's Avatar
Im pretty sure I know where the fault was; I bought the car from a guy that claimed it was already tuned and I was nieve enough to take his word for it. Everything SEEMED legit: clean motor, good compression, nice turbo setup so I figured I could at least trust the tune well enough to hit boost once or twice... Sh** was I wrong.
Dont get me wrong, im not crying over spilt milk, I just want to get the car back to full potential and get it on the dyno. Just for reference here is my current setup:
Precision sc60 .70cold/.63hot
Fullrace a/c compatible ramhorn
Tial 44mm wastegate
Tial BOV
RC 1000cc injectors
Walbro 255 lph
3" exhaust dumped under cab
VictorX I'M
3 bar map sensor
Im hoping to push ~350 to 375 horsepower with my current tuebo setup
So my budget for rebuild is roughly $1000 and like I said before, want tge most "bang for my buck".
question 1: If I were to decide to rebuild the gsr, would it be necessary to bore over the block considering the ringland cracked? I was told that it would be pointless and way beyond my budget to rebuild the gsr, is this true? How much am I looking to spend to rebuild it? (oem spec vs. forged internals?)
question 2: Would it be more affordable to buy an ls motor and build ls/vtec? Are there any tradeoffs of having an ls/vtec turbo vs. gsr turbo?
Sorry for 30,000,000 questions and thanks in advance for any help/advice.
- Josh
Old Apr 18, 2011 | 08:39 PM
terbear4god's Avatar
just find a whole creigslist gsr motor drop it in done.
lsvtec is not a easy build theirs alot more than meets the eye
Old Apr 18, 2011 | 08:45 PM
CanadianEF9's Avatar
and another thing with the ls vtec their is more money for the conversion kit and the bottom ends dont like the high revs and tend to spin more rod bearings. i would find another gsr shortblock or have yours rebuilt
Old Apr 18, 2011 | 08:51 PM
racebum's Avatar
x2
if you didn't damage the crank of mains it's totally do able if you do the assembly yourself
Old Apr 18, 2011 | 09:06 PM
REDEM1FTW's Avatar
Icon3 Re: Gsr turbo - cracked ringlands, what are my options?
G
Originally Posted by racebum
x2
The motor is still in the car but im pretty sure its just the ringland.
Would it be a feasable task to rebuild the gsr myself WITHIN MY BUDGET if I go with an aftermarket rod/piston setup, new bearings, getting it bored over, hg and arp headstuds? I can do the assembly work myself
Is boring over necessary or will a simple re-hone suffice?
Old Apr 19, 2011 | 05:07 AM
BigMike0147's Avatar
OK. I'm currently in your situation (broken ringlands), but with an LS motor. Here are some of the costs of my build just so you have a perspective....
Forged internals - 620 and that's with a hell of a deal on some new rods
ACL Race Bearings - 120
ARP Head Studs - 130
Boring Block if you need it - 100, probably 20 or 40 to just hone
OEM Head Gasket - 70
OEM Oil Pump (if want) - 70 or more
Fluids - 50 to 100 probably (multiple oil changes for breakin)
Tune the Car - 400
So, with that, you're looking at over $1K BEFORE the tune at a reputable shop. Yes, it will be a lot cheaper without forged internals. But you will still need to replace AT LEAST one piston, My compression check came out similar to yours where only one cylinder showed low compression, but when I got the motor apart there were 3 bad pistons. You would also need rings and have the pins pressed into the rods.
I'm not trying to turn you away from this idea, but I just wanted to put some numbers with it so you can try to decide what you want to do and what parts you want to use. If you'd like to talk more (as I could for a while about this, lol) just PM me
Old Apr 19, 2011 | 09:19 AM
Johnnydc's Avatar
just burn ur car up and collect insurance bibb lol jk
Old Apr 19, 2011 | 09:28 AM
REDEM1FTW's Avatar
so we have a general consensus that with my budget and power expectations it would be my best bet to rebuild the gsr with forged internals? im 95% sure im going the forged gsr route
and thanks big mike for the price rundown, it really help put things in perspective. be expecting a pm soon id like to get some opinions/advice on a couple things.
Old Apr 19, 2011 | 09:29 AM
REDEM1FTW's Avatar
lol too bad the KBB on my hatch is $900 excellent condition, id get it hard from insurance no spit or lube haha
Old Apr 25, 2011 | 06:40 AM
No problem. What part of TX are you in?? I'm south of Houston myself.
Old Apr 25, 2011 | 07:18 AM
sp00led's Avatar
I cracked a ringland on a gsr bottom end. I had a friend replace the the piston/rings while the motor was in the car. He removed the cylinder head and oil pan but the block was still in it.
The motor ended up going back NA and has been running strong ever since.
Old Apr 27, 2011 | 08:17 AM
REDEM1FTW's Avatar
Im actually a little south of dallas haha
Old Apr 27, 2011 | 08:23 AM
pcguy760's Avatar
Also, head lift can destroy ringlands. How? Head lift ---> HG Failure ---> Antifreeze being dumped into the cylinders ---> Pistons / cylinders get "washed out" ---> bye bye ringlands and more...
You should definately get the ARP Headstuds
Are you actually building your engine or are you giving it to a shop? This would have saved you alot of money and time too...
Old Apr 27, 2011 | 10:06 AM
REDEM1FTW's Avatar
arp headstuds came in yesterday, hg is fine, and im taking it to the machine shop to get bored .20 but i am assembling everything myself.
rundown on what i plan to do:
.20 over bore
head decked
new oem headgasket
arp headstuds
new oem bearings
JE (81.5mm) 9.0:1 pistons with Eagle rods
im also considering upgrading my valvetrain to dual valve springs and retainers, would it be worth the extra money considering i have a .70 trim turbo with a victor x manifold so that i can pull more power out and not run out of rpm's?
Old Apr 27, 2011 | 10:17 AM
92redhatch's Avatar
Sounds like a great idea.
Old Apr 27, 2011 | 10:30 AM
REDEM1FTW's Avatar
which part? lol
i just dont wanna have "too much turbo" and not enough "motor" lmao
Old Apr 27, 2011 | 12:30 PM
TheShodan's Avatar
Moderator
That sounds like that is the best option instead of disposing of another perfectly good engine that can be rebuilt.
Old Apr 27, 2011 | 12:37 PM
92redhatch's Avatar
Just go forged Internals. If you do the work yourself just make sure the machine shop does give you a good piston to wall clearance and plasticguage your bearings and you'll be fine
Old Apr 27, 2011 | 02:23 PM
pcguy760's Avatar
.20 over bore
head decked
new oem headgasket
arp headstuds
new oem bearings
You do know that this is gonna be way over your 1K limit right? Not trying to throw you off but if were you, I would take my time and do all of the above you mentioned. Thats a nice plan you have there
Old Apr 27, 2011 | 05:09 PM
REDEM1FTW's Avatar
haha im already ***** deep into this thing, but yea i realize that its gonna cost some moneyzzz. I guess its better to build it right the first time than have to build it 3 more times bc i cheaped out lol.
If i get the springs and retainers, i will probably have to hold off on the tune for ~ a month-month and a half.
SO BIG QUESTION IS,
- Should i invest the extra money in dual valve springs and retainers?
Old Apr 27, 2011 | 05:12 PM
REDEM1FTW's Avatar
i see in your sig that you are making some pretty good numbers, do you mind me asking what engine/turbo setup you have? i would really like to see what kind of numbers i should be expecting with my car to and would also like to see what setups have worked for others? if so, a pm from you would be nice
