rpm rebuild kit?
has anyone used this d16a6 kits before thinking about getting this one or the fj distributors hi compression kit i wana stay with a stock bore tho cause i gotta pass ca smog
http://www.rpmmachine.com/shop/index..._detail&p=4602
http://fjdistributors.com/product_in...roducts_id=139
i would us the FJ...
you can stay your stock bore, but it will by higher comp pistons. (depends on the pistons they give you)
and you might not pass smog.
if you want to stay stock and pass smog, just go with the RPMmachine set.
slimjimming6688
Dec 15, 2008 08:23 PM
Luserkid
Aug 3, 2003 03:30 PM
