ticking and low oil pressure light
i made a few other post's but i thought this would be easier.. So i have and oil light that flickers at low rpm abd go's away at anything above 1200rpm.. Also the head seems to be ticking like valve's i heard im suppost to adjust them. Is it ticking because of the oil pressure? Its re-built d15b1 block and d15b7 head. i re-built block. Has new rod bearings,main bearings and rings. Could it be oil pressure switch or more than likley the oil pump screen? Praying its not the last on the list... OIL PUMP. Any help would be appreciated sorry for so many post.. thought id combine them...
it misfire's but i think thats because of timing. It runs amazing tho when u step on it. 95mph in 1/4 mile i dont know what she runs but i can keep up with a 14seccond 240sx. So i dont think its something to bad.. Maybe just clogged
HAHAHA people actually put oil in the washer fluid! Oh geez... ya iv been re-building engines long enough to know where oil go's so yea. I checked the pump it looked ok and when the valve cover was off i put all oil on the cam to get it all lubed up so im sure is got oil plus i check dip stick alot.. Its a habbit cuz it used to smoke and use a crap ton of oil before i did the rings. i cleaned the oil pump strainer thing before re-install.. Maybe the gasket thats go's between the strainer thing and the pump itself is bad cuz it forgot that there even was 1 till i was looking at price's... Ima try that cuz its cheapest.. and if that dont work ill replace pump, sensor and the strainer thing.. Thing is i have no money or job so its hard 2 do. If i had money id do it all anyways but idk.. Thanks for the reply.. Ima noob at something engine but i do know alot and deff know where oil go's but good suggestion for my friend he dont know where that stuff go's hahahaha
Yea i found the problem tho.. I used std size bearings and it needs 0.25mm bearings.. So i orderd them should be in next few days ticking noise is actually a knock just a quiet not bad 1. That would also cause low oil pressure. Plus it was over filled by half qt. Forgot i put oil in filter and so i put 4 qt's in and the half in filter. Problem solved Thanks tho man. Helped me get it :D
Yup u put a little in the filter so it dont have a dry start.. And i will deff post when i get her back together. heres a pic of her beautiful power plant! People underestimate these SOHC D-series i love it! Built mine from ground up and couldnt ask for more.. Gonna do more tho :D'
This is the picture of it when i got it......
This is it now!
This is it now!
Yea just went trought the same thing on my gsr motor.my oil pressure light came on and my gauage was reading almost 0 pressure. i took the oil pan down and noticed it did not look clean how its supposed to be i then looked at the oil pick up tube and realinzed it was completeley obstructed. I didnt take and chanced. I inspected the bearings and seamed fine. Oil pump looked like it seized up. I put a new pump. cleaned the oil pan and and put it together now have perfect oil pressure. As for the noice def. a valve lash . mines did the same thing. after valve lash car sounds very quiet.
So i think im just gonna get the d15b7 block and put it on this new head and re-ring it then call it good. Tired of messin with this crankshaft. nowhere will turn it down here in hutchinson they all want 200bucks and well a new 1 is 200bucks so ill just swap it with a good crank from my friends honda
So every1 i decided to put a D15B7 block BRANDNEW in.. It has brand new crankshaft.rods,pistons and rod and main bearings this motor will have no miles on it at start up! Should be very reliable and quick! ill upload a pic or video of the car in action :D
So i put the new engine in and all i gotta say is O my gosh! Its way faster only got on it 1 time and it was enough for me. Cant be to hard on her yet but i will when shes fully broke in!
?? why can't you? i've been beating on my rebuilt a6/z6 mini me since first start up. i used the redline first, shift to third then decel in gear downshifting as rpms drop to seat the rings and it runs great, no blue smoke (just some black at WOT) and i have no cat. hit redline several times each day
Well iv broke her in and now it go's 0-60mph in 7secconds flat i missed 2nd gear and ran 97mph in the 1/4 mile and beat a supercharged gtp it was stock but i was like
And its amazing wish i had a tach tho lol. Its amazing no blue smoke except from the exhaust system from when it did smoke.. Only at high rpm its not doing it as bad now its just burning off all the old stuff! Its amazing id be happy with a 14 1/4 mile some day i hope
Yea you dont need to put oil in the filter people only do that with engines that the filter is vertical but on our engines its horizontal so starting dry isnt a problem.
oh lol news 2 me i didnt know lol...
Hey check out my race. I raced a chevy s10 with 5speed new clutch k&n intake with magnaflow muffler and cat. And he has new tires i beat him by alot! And i also raced a RX-8 and beat him by alot 1st race he missed 2nd and the 2nd race he beat me by 1 and half cars and its cuz i missed 3rd.. 2007 RX-8 wanna see? Check it out
http://www.youtube.com/watch?v=WrSE6dRtCHg
http://www.youtube.com/watch?v=qEJ-XpyYgu4
garthjenkins
Aug 6, 2011 01:35 PM
EJ1_Can2
Oct 6, 2010 10:48 AM
