D16A6 Spring pin (bitch pin)
Old Apr 17, 2011 | 07:17 PM
thebluecrx's Avatar
Default D16A6 Spring pin (bitch pin)
Mine fell out and I have no idea what size I need or where to get one. Can anyone help? I don't want to do any of the ghetto rig crap either I want to fix it the right way.
Old Apr 17, 2011 | 07:31 PM
beansandrice's Avatar
Default Re: D16A6 Spring pin (bitch pin)
Honda dealer. 5 bux done.
Old Apr 17, 2011 | 08:19 PM
thebluecrx's Avatar
ok thanks. can anyone tell me how to install new shift bushings?
Old Apr 18, 2011 | 04:51 AM
it is self explanitory. In my opinion it is a level 1 ease upgrade.
Old Apr 18, 2011 | 01:51 PM
thebluecrx's Avatar
http://www.summitracing.com/parts/ENS-16-1102G/ this is the set im looking at. where exactly are they on the shift linkage thats what has me confused
Old Apr 18, 2011 | 02:05 PM
thebluecrx's Avatar
also the boot covering the spring pin came off do i need to get another one? or is it ok to go with out it?
Old Apr 18, 2011 | 02:10 PM
DumpdEJ6's Avatar
I like the tuna here
I drilled the hole out until I could fit a bolt and teflon nut through it perfectly, which really helps if you have to take it off again, lol.
Old Apr 18, 2011 | 03:03 PM
Projekt_Ef9's Avatar
The cover helps hold in the pin. The rectangular looking budging goes behind where the shifter goes through underneath and I'm pretty sure the circle ones go on the end of the stabilizer bar where it connects to the trans. I'm not positive about the circle ones though.
Old Apr 18, 2011 | 04:25 PM
thebluecrx's Avatar
i got a 5/16x1'' compression pin and stuck in there it went in kinda easy so i put good old duck tape around it a few times hopefuly itll hold until the actual size pin comes in
Old Apr 18, 2011 | 07:43 PM
Jockone's Avatar
When you put the right bitch pin in it will hold fine without the boot,there should be an other spring clip that goes around the linkage after the pin goes in.
Old Apr 19, 2011 | 03:40 AM
Ghetto ducktape ftw!
Old Apr 19, 2011 | 05:37 PM
thebluecrx's Avatar
http://forums.g2ic.com/showthread.ph...uild&p=2137906 will this u joint rebuild work on a 89 crx si?
Old Apr 22, 2011 | 09:38 AM
thebluecrx's Avatar
anyone still around? this is my daily driver and i really need it fixed
Old Apr 22, 2011 | 02:55 PM
.Manny.'s Avatar
Touching My Member
go get the pin. put it in. done.
Why are you trying to rebuild anything?
Old Apr 22, 2011 | 09:26 PM
tonylovesjdmEF9's Avatar
true that i have the pin with out the cover and no problems yet also use the oem honda pin save your trany save your the worries and even tho a bolt and nut seem like a good idea its not cuz vibration will loosen stuff up unless you have a locknut or loctite i used a nut and bolt i screwd up my trans =( so now i use the pin
Old Apr 23, 2011 | 06:11 AM
B16-CRX's Avatar
Go to a junkyard if you can't go to Honda. I don't understand why you are still asking for help. Tell them you need a bitch pin and they will know what you are talking about.
Old Apr 24, 2011 | 07:34 PM
thebluecrx's Avatar
i got the pin. the bushings in the u-joint of the shift linkage are completely shot and the shifter has alot of play while its in gear and is really loose i'm not a moron i have the bitch pin and am going to replace it but while i was down there i was going to do the rebuild that is in the link i posted if it will work
Whatislove
Honda Civic (2001 - 2005)
15
Apr 2, 2011 05:47 PM
Joe-G
Feb 22, 2008 11:03 PM
tx95excoupe
10
Sep 17, 2007 11:55 AM
BDogggUT34
Feb 11, 2005 03:46 PM
EM1_GIL
May 10, 2004 09:36 PM
