timing belt!
Old Apr 17, 2011 | 05:50 PM
eg2_RE's Avatar
Default timing belt!
Does anyone know how much torque i need in a impact gun to remove the crank pulley bolt off?
Old Apr 17, 2011 | 06:01 PM
fonkernuckle's Avatar
Default Re: timing belt!
I set mine to max and if its the first time to take it off for you it might not be enough.
You might have to resort to using other means to include: the hex tool that holds the crank pylley with a breaker bar on it and a cheater bar on the breaker bar and then the countering pull to remove the bolt: using impact socket with long extension (all these are 1/2 inch drive minimum) and another breaker bar on the extension(I use a 3/4 breaker bar) and another cheater bar (long as possible) on the breaker bar.
Some will say to use a screwdriver etc on the teeth of the flywheel/torque converter(removed starter) but if the bolt has been on there since factory, its not going to cut it. IMO flame on its IMO also make sure the socket is also a 6 sided one and not twelve sided
Old Apr 17, 2011 | 06:50 PM
TravisB16a's Avatar
Definatley gonna need the hex tool to hold the pulley still. I just did a belt yesterday and I had to use the hex tool then I had to put my back against the wall and my foot on the breaker bar. When I did a belt on my 90 civic that had never had pulley bolt out , we had a torch breaker bar and a huge cheater bar on it .
Old Apr 17, 2011 | 07:07 PM
el crapitan's Avatar
3/4" impact
Old Apr 17, 2011 | 07:29 PM
eg2_RE's Avatar
thanks guys sorry but where can i get that hex tool? how does it look like so i know what to look for at kragen or something.
Old Apr 17, 2011 | 07:55 PM
check amazon they have it at times, although I got mine from fleabay
Old Apr 17, 2011 | 08:06 PM
rlacsamana1989's Avatar
if you have an air impact wrench that is good you won't need the hex tool to get it off but to put it back on yes.
you can rent a hex tool from o'riellys its called the honda crank pulley holder
you pay the deposit and get it back when you return it.
what i had to do is drive it to a shop they turn the wheel and use their gun and got it off in a matter of seconds then tightened it just enough to drive back home to get at it with a drive
look just like this, it is on their list of tools to rent on their counter. they will know what your looking for.
Old Apr 17, 2011 | 08:08 PM
sayanything's Avatar
autozone has it for rent. Its called a "honda crank pulley holder" looks like a big hexagon? 6 sided, with an attachment point for a 1/2 in breaker bar. This is what it looks like
http://www.toolking.com/performance-...LAID=526417894
Old Apr 17, 2011 | 09:49 PM
eg2_RE's Avatar
thank you will go to autozone/o'reily to check it out
Old Apr 18, 2011 | 10:40 AM
FTP racing's Avatar
http://cgi.ebay.com/ebaymotors/Acura...motiveQ5fTools
Just buy the tool don't waste your money to rent! Good Luck!
Old Apr 18, 2011 | 12:28 PM
you don't pay anything to rent the tools from them. you leave the deposit to take it out of the store and get that money back when you bring it back.
they do that so you don't buy a tool that is only going to get one use and then return it and then they have a used tool on their hand.
some people are already in the process of doing their project and they don't want to wait for it to be mailed to them.
Old Apr 18, 2011 | 03:47 PM
NUISANCE's Avatar
I'm in the bay area, if you need to use mine you it's all yours and I won't charge you a dime.
Old Apr 18, 2011 | 07:57 PM
you are a good guy. thank you for this display of kindness to a random stranger. Id do the same.
Old Apr 20, 2011 | 10:36 AM
NUISANCE's Avatar
I think the community as a whole would be better off if there were more guys like you and me.
Old Apr 20, 2011 | 08:41 PM
Hidenplanvew's Avatar
800ft lbs works for me.... But get the holder I use it alot!
kornerk12
Apr 15, 2007 07:37 PM
accord93racer
Aug 13, 2005 06:06 PM
90crxterror
19
Apr 7, 2005 10:10 PM
cyberneo344ib
May 10, 2004 04:28 AM
NXSpoon
May 15, 2003 07:05 AM
