need help... my Brake Lamp indicator is lit and I have no idea what the problem could be
Old Sep 28, 2002 | 04:02 PM
eujin's Avatar
Default need help... my Brake Lamp indicator is lit and I have no idea what the problem could be
whats up guys, I seem to have stumbled upon this problem a few days ago. while i'm warming up my car, as soon as I depress the brake to shift into gear the Brake Lamp light comes on. now i've checked all the bulbs and they arent blown, and I also checked the fluid levels, they are fine as well. what could possible be the problem? 92 Prelude Si auto
Old Sep 28, 2002 | 05:16 PM
Cottonwoodz's Avatar
Default Re: need help... my Brake Lamp indicator is lit and I have no idea what the problem could be (eujin)
Mine used to do that all the time. Got my swap done (H22A) and the problem never came up again. Must of been the ECU in my case.
Old Sep 28, 2002 | 05:44 PM
Chiovnidca's Avatar
Usually a bad bulb or socket. Get someone to step on the brake and make sure all the bulbs are burning bright. Don't forget about the third.
Old Sep 28, 2002 | 05:57 PM
H23 Power's Avatar
Default Re: need help... my Brake Lamp indicator is lit and I have no idea what the problem could be (Chiovn
mine is lit up also...all brake lights/brake lights work fine
Old Sep 28, 2002 | 06:31 PM
Chiovnidca's Avatar
Have you checked the brake light failure sensor?
Old Sep 28, 2002 | 07:10 PM
eujin's Avatar
theres a brake light failure sensor?? please let me know where its located so I can check it out. is there a CEL code that shows for this type of failure? i'm gonna have to check and see if there is one. thanks guys
Old Sep 28, 2002 | 07:16 PM
eujin's Avatar
double post
[Modified by eujin, 4:17 AM 9/29/2002]
Old Sep 28, 2002 | 07:34 PM
2001se's Avatar
When the Brake Lamp indicator is on, doesn't that mean the Emergency/Parking brake is activated? Is your Emergency/Parking brake lever all the way down?
Old Sep 28, 2002 | 08:12 PM
Gabe's Avatar
Have you checked your brake fluid level or your brake pad thickness. I had my brake light come on and it was because my pads were worn. I think this is might only apply to the 5th gen though.
Gabe
Old Sep 29, 2002 | 05:07 AM
Chiovnidca's Avatar
No, that's the brake light. The brake lamp light is totally different.
Old Sep 29, 2002 | 06:11 AM
vicz's Avatar
have the same EXACT problem with my 92 lude si.. mus be a fuse or something.. cuz nothin on my car is blown out either.. it has now become apart of my dash. it makes it look pretty..
Old Sep 29, 2002 | 12:34 PM
mattmw88's Avatar
Default Re: need help... my Brake Lamp indicator is lit and I have no idea what the problem could be (92lude
I thought this was only my lude. This has happened before and after my swap, but the wierd thing is that I can just turn my car off and it doesn't come back on the next time I start it...
Old Sep 29, 2002 | 01:05 PM
714's Avatar
714
I have the same prob on my 93 si auto, sometimes its on sometimes its off. Ive learned to ignore it
Old Sep 29, 2002 | 02:16 PM
EH2DX's Avatar
same thing with my g/f's 92 prelude SI. i guess this is a common problem for that model...
Old Sep 29, 2002 | 02:26 PM
H23 Power's Avatar
Default Re: need help... my Brake Lamp indicator is lit and I have no idea what the problem could be (BB1)
hmmm, i'm gonna do my rotors/bads soon, maybe that will solve it...i dunno, i just grew used to it like the rest of the guys
Old Oct 9, 2002 | 12:47 PM
WOTTEG's Avatar
Default Re: need help... my Brake Lamp indicator is lit and I have no idea what the problem could be (H23 Po
I have the same problem with my 2000 Integra LS.
The brake light in the dash comes on while the engine warms up (driving).
Sometimes by hitting the brakes it will go away. It will turn back on a few seconds later though (until the engine reaches operating tempurature).
I have test3d and verified that the parking brake switch is functioning properly.
I have also verified and (slightly) overfilled my brake fluid with (dealer purchased) honda DOT3 brake fluid.
My pads I have not checked, but I do have new ones. Maybe that will fix it.
I'm stumped. Good Luck.
mrmyass
Mar 11, 2015 11:02 AM
1fastefhatch
Dec 8, 2008 08:01 AM
GSRteggy00
Sep 27, 2006 09:46 PM
low430
Oct 30, 2005 01:02 AM
