Suspension & Brakes Theory, alignment, spring rates....
Is this the correct proportioning valve?
Old Apr 17, 2011 | 05:09 PM
averyvm's Avatar
Default Is this the correct proportioning valve?
Doing a disc swap on my 93 hatch.
Is this the correct proportioning valve needed for the swap?
http://cgi.ebay.com/ebaymotors/1991-...Q5fAccessories
Old Apr 21, 2011 | 12:32 PM
94EG8's Avatar
Seagull Management
Default Re: Is this the correct proportioning valve?
No, that's from an ABS model from the looks of it. You need a '90 - '93 non-ABS Integra prop valve (you will need to reuse the metal brake that bolts to the firewall from the civic) or use a '94 - '97 Integra non-abs prop valve (bolts right on with the integra bracket)
jdmark1
Apr 3, 2019 07:17 PM
10cjennings
May 14, 2014 06:01 PM
Ninety3 Integra
Suspension & Brakes
Jan 16, 2013 08:20 PM
Fo-Do Fanatic
Aug 18, 2010 10:15 PM
LSej1
Jul 8, 2008 03:23 PM
