LS/VTEC Headstud ?
Old Apr 16, 2011 | 03:27 PM
cinder0159's Avatar
Icon2 LS/VTEC Headstud ?
Im not sure what headstuds to use on my b18A/b16A setup. The B16 head came with arp head studs. I did a mock up and it looks like they will work but I wanted to get some advice before moving on. Any Suggestions?
Old Apr 16, 2011 | 03:31 PM
cinder0159's Avatar
Default Re: LS/VTEC Headstud ?
Old Apr 16, 2011 | 06:53 PM
shiftmx179's Avatar
Use GSR headstuds
Old Apr 16, 2011 | 07:10 PM
mik101's Avatar
Originally Posted by shiftmx179
Use GSR headstuds
The GSR ones are the correct ones, but if you have the B16A headbolts there, compare them to the B16A studs. They may actually be longer than the stock bolts.
You can't use the B16A head bolts due to them being too short, but I have heard of people getting away with the studs (I'm guessing they're actually a little longer than the stock bolts).
If you search carefully someone has posted the two measurements together.
FWIW I used GSR studs in my B20V.
brian3676
Dec 14, 2005 05:45 PM
SPOOLINmatt
Apr 8, 2005 12:40 PM
jdmhatch94
Aug 3, 2002 04:57 PM
paulzy
Nov 9, 2001 03:41 AM
jboostedhatch
May 2, 2001 09:56 PM
