Welding inside flanges
Old Apr 16, 2011 | 05:43 AM
92cxturbo's Avatar
Default Welding inside flanges
How are you guys welding the inside of your collector and head to runner flanges without warping? Or are you not welding the inside?
I read alot of people saying to weld the inside of the head and collector flange. I bolted my flanges to a solid piece of 1" al. when welding to keep eveything stright, but how do I weld the inside without it warping? TIA
Old Apr 16, 2011 | 08:56 AM
weiRtech's Avatar
OG Fabricator
Default Re: Welding inside flanges
just weld a small amount at a time (1" or so) and let it cool before you weld on it again. i don't like to use aluminum for head/turbo flange bolt down plates because i find it bends. i use a 1.25" mild steel plate. i have a couple alum v-band heat sinks though. hard to bend a big fat round piece of aluminum with a v-band ring.
Old Apr 16, 2011 | 09:33 AM
CRMB's Avatar
OG Fabricator
Aaron who killed your website? No backup?
Old Apr 17, 2011 | 06:28 AM
91jdmhatchback's Avatar
There is no need to weld inside the head flange on a manifold made of sch10/40 unless you have some fitment issues to deal with. Now on a turbo flange you can weld inside but it will 99% of the time be for cosmetics or for flow reasons (eliminating sharp edges for smoother transitions and such).
There should be no warping if you don't look at it as a weld for strength in the part and weld it cooler. (you don't want burn through on the back side anyways as that will look like crap).
I have never had a v band warp on me, but i pulse weld all thin material as of late.
Old Apr 18, 2011 | 07:03 AM
92cxturbo's Avatar
Cool thanks for all the info.
CreeWorks
Welding / Fabrication
Mar 30, 2010 01:30 PM
Justin Olson
20
Jun 10, 2006 08:54 AM
BEEYOND
Jan 26, 2006 12:45 AM
wade
15
Jan 10, 2005 08:32 AM
Optiks.
Nov 27, 2003 12:29 PM
