2001 Integra GSR tach stops working above 6,000 rpms
I finally figured out why my ar was revving up strangly, but I still need to fix this tach issue. For whatever reason when I go above 6k rpms (which is very close to VTEC engagement as far as I can tell) the tach dops to zero. As soon as I let off and the engine drops below 6,000 rpms it works fine. I am running a OBD2A JDM GSR swap with the OBD2A JDM GSR ecu through a jumper harness. Everything else works fine, and there are no cels, even when revving above 6k. Any help would be grealy appreciated as he car is sold as soon as I get this fixed. Thanks!
It feels like VTEC is actually working? Sounds like a wiring issue, like perhaps the VTEC signal is touching something else on the way to the solenoid...
Yes it feels like VTEC is actually working. I was kind of thinking bad jumper harness or wiring harness myself. I guess it could also be in the ecu as well. The harness is an oem OBD2 GSR harness which is not hacked up or anything. The only things I can add would be that the VTEC solenoid is the jdm solenoid with only one connection, not two like its USDM counterpart. I will keep checking the harness, but it looks very clean. I might try a jumper wire from the tach to the cluster to rule a wiring issue out.
I don't know if this will help or not but I was having tach issues with my 97 gsr and it was because the ground wire inside the distributor was poorly connected.
Replaced the ignitor, and it does the same exact thing. I will takethe dizzy off and recheck all of the wiring one more time. You never know, and it sucks, because I sold all 3 of my OBD2 distributors thinking this one would be fine. Damn!
It's your JDM Vtec Solenid, or ECU. You'll need to purchase a USDM vtec solenoid that comes with the green oil pressure switch. Then run the wires to the ECU. You might need a chipped p28 ECU.
How do I know this? injust installed my JDM B18C GSR motor which I purchased from HMO and I ran into the same problem. fuel kept cutting off at 6k RPM and vtec wouldnt engage. I took it to the shop, installed a USDM solenoid and ran new wires to firewall to ECU and BAM fixed the issue.
However, my original ECU that came with my motor was throwing an ERROR code, which blocked off the connection to the knock sensor, so although vtec engaged it was very soft and light. My tuner recommended me to go with a p28 chipped ECU, with just a street tune. Now vtec kicks in hard :D
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
I fixed the issue last night. It was not the ignitor or coil, but the other sensor that is located in the distributor. Everything works fine now except for the fact that I still get an error reading when hooking up an OBD2 scan tool. I might just do the CKP trick and run my original USDM ecu.
I guess it could have also been a wire short within the distributor as well, but at least it is fixed!
Hey man, i know this is an old thread. But i have the same problem. although i didnt think its any of the sensors in the dizzy, because the problem only started occuring when i plug in an ecu that requires a wiring jumper harness. Where did you get your harness from? and did you have to do anytihng to it wiring related, thats.
