Where is a good place to buy an engine harness?
Old Apr 15, 2011 | 09:34 PM
micah92integra's Avatar
Default Where is a good place to buy an engine harness?
I have a 1992 Integra gs automatic and i am in need of an engine harness. i have come up short every time i look for one. can someone please point me in the right direction as to where i should look? thanks.
Old Apr 15, 2011 | 10:33 PM
JdmTypeRdc2's Avatar
Default Re: Where is a good place to buy an engine harness?
Try the classifieds on here, craigslist, T-I.net, eBay and junkyards. If all else fails, call up rywire or chase bays and get one from them...it will be a pretty penny though
Old Apr 16, 2011 | 05:36 AM
fcm's Avatar
fcm
Old Fart
Where are you? 94
Old Apr 16, 2011 | 05:56 AM
i live in louisville
Old Apr 16, 2011 | 06:49 AM
Scorchin Civic's Avatar
Ya, that's a kind of hard harness to fine since you can only get one from a 1992-1993 automatic Integra.
Old Apr 16, 2011 | 08:31 AM
that's what i am running into. if anybody has any ideas, let me know.
Old Apr 16, 2011 | 10:14 PM
fcm's Avatar
fcm
Old Fart
I see your problem, not a lot of G2s at your closest PicknPull... http://www.picknpull.com/check_inven...ra&Distance=20 my PicknPull has a few of them...http://www.picknpull.com/check_inven...ra&Distance=20
Is it the same at all the bone yards down there?
Say, maybe I can make a buck here, if I was to find an engine harness off a 92-93 automatic GS, [is that a 1.8L VTEC?] what is it worth?
I have to go to PicknPull tomorow anyway. 94
Old Apr 17, 2011 | 11:02 AM
JDM_JUNKIE_DA's Avatar
i got a harness spliced reverse sensor n missing map sensor 92 obd1 engine harness $30
Old Apr 17, 2011 | 12:42 PM
I could definitely go 100 for one if it is complete and unmolested. sounds good if you are willing to do that. thanks
Old Apr 17, 2011 | 11:45 PM
bump
Old Apr 18, 2011 | 09:47 AM
This is a 92 integra automatic harness? was reverse sensor spiced to accommodate a manual tranny? can a map sensor pigtail be spiced back into this harness?
Old Apr 19, 2011 | 11:12 AM
fcm's Avatar
fcm
Old Fart
I will look this weekend. 94
Old Apr 20, 2011 | 05:03 AM
I appreciate it. thanks
Old Apr 20, 2011 | 05:04 AM
oh, and it is a B18a1.
Old Apr 20, 2011 | 05:55 AM
fcm's Avatar
fcm
Old Fart
OK, to be clear the B18a1 is a 1.8L non VTEC engine found in 90-93 Integra, there are two versions of the engine the 1st gen., [90-91] was a 130HP unit and the 2nd gen., [92-93] was a 140HP unit, so the only one that will work is off a 92-93 automatic Integra, is that correct?
If so there are 4 of them at our PicknPull 2x92 and 2x93, can't tell if they are auto or not untill I go there, but your looking for just the engine harness, correct?94
Old Apr 20, 2011 | 07:11 AM
You can get him any auto harness from 1992-1993 Integra
Old Apr 20, 2011 | 11:10 AM
fcm's Avatar
fcm
Old Fart
Thanks, now I will just have to see if the ones that are there are any good, I know 3 of them are automatics, pretty sure at least 2 of them still have the engines and one has just the head pulled.. 94
Old Apr 20, 2011 | 11:23 AM
JoHnnY LonGHoRn's Avatar
Rywire, chase bays try to stay away from spaghetti
Old Apr 21, 2011 | 06:56 AM
ok, thanks. definitely a 92-93 harness. engine harness only. thanks for the help fcm.
Old Apr 21, 2011 | 10:58 AM
fcm's Avatar
fcm
Old Fart
Will be going there tomorrow as we are closed for good Friday, keep your fingers crossed that there is a good one there. 94
Old Apr 22, 2011 | 01:37 PM
fcm's Avatar
fcm
Old Fart
Just got back from PicknPull, the news is not good, there was a 93 4door, [sedan] auto with engine pulled but harness still there, however the numb-nuts that pulled the engine cut the leads of every plug on the engine except the injectors.
There was also a 92 3door, [hatch] auto that had just the valve cover pulled but 3 plugs had been cut from harness the rest was intact and in good shape.
F%*K I hate A-holes that do that kind of ****, also found a 94 GS-R, [engine pulled] but with mint black door panels, [I have been looking for for 3 years] other then the front lower corners that some other dumb-*** had bent [damaged] to get at speaker, and all he had to do was pop the grill.
Sorry I could not help. 94
Old Apr 22, 2011 | 07:34 PM
No problem, i think i located one in tennessee so things turned out ok anyways. thanks for your help.
12345678910jdm
Jul 25, 2011 03:01 AM
ca-rs
Jul 12, 2008 07:02 AM
Hittnthebz
Dec 20, 2007 06:13 PM
