95 Accord F22b Swap and Boosted Wont go past 5k without fuel cut
Old Apr 15, 2011 | 04:24 PM
BoostedAccord95's Avatar
Default 95 Accord F22b Swap and Boosted Wont go past 5k without fuel cut
f22b boosted 9lbs it wont go past 5k with out a really bad fuel cut it only started doing this after i put new trans in and now check engine light stays on.... It does this with and with out boost so idk what it could be ANYHELP THANKS
Old Apr 15, 2011 | 04:29 PM
daltond88's Avatar
Default Re: 95 Accord F22b Swap and Boosted Wont go past 5k without fuel cut
check your ground wire to your tranny? a bad ground will make any motor run shitty. hell i swapped this motor in my accord from a usdmf22b1 and i had the hardest time to get it to run right something was always effed up on it. Good Luck!
Old Apr 15, 2011 | 07:58 PM
nicefighter80's Avatar
Which code is it and do you have 2-step/anti-lag on your ecu?
Old Apr 17, 2011 | 03:36 PM
Have not checked the codes and yes has 2 step
Old Apr 17, 2011 | 05:24 PM
I been readin up on limp mode but idk seems not to always stay at 5 grand will go over i guess ill half to run the codes its throwin
Old Apr 17, 2011 | 05:58 PM
GhostAccord's Avatar
Why do you say it has a fuel cut? What does your air fuel ratio look like?
What injectors are you running and did you have your setup tuned on a dyno?
Old Apr 17, 2011 | 06:31 PM
im not sure if it is a fuel cut now i was thinkin the tune was bad but then i got a new boost gauge and it reads perfect 9lbs everytime and i ran it without the boost and it still likes to stop at 5k im runnin black top 450cc injectors and the tune was done by Ycunderground.com
Old Apr 17, 2011 | 06:34 PM
And i just tryed to unlook neg battery cable and ECU Fuse but still as soon as it starts not 5 sec later BAM engine light
Jump the SCS connector under the glove box and read the CEL flash codes. Or if you already know what codes it's throwing post them up.
Old Apr 17, 2011 | 07:01 PM
I gotta take it to autozone or something cause i cant find anyone with a obd1 code reader
Old Apr 17, 2011 | 11:06 PM
holmesnmanny's Avatar
Use yourself to read the codes.
Old Apr 18, 2011 | 08:18 AM
Wish i could
Old Apr 18, 2011 | 08:28 AM
Accordin2me's Avatar
Jump the 2 pin orange connector under the pass side kick panal and turn the ignition to on, then count the flashes on the cel its like morse code kinda
Old Apr 18, 2011 | 11:02 AM
Read the codes from the ECU and trouble shoot accordingly.
Self diagnosis is done the same way as on the Civic's & Teg's. I have done it more than a few times myself. There is a blue 2pin/wire connector attached under your glove box/side of the passenger footwell. That is the one that you short to do the SCS self diagnostics.
This is the procedure I used for my 96 Accord.
Here is the blue plastic retainer that is connected to the chassis. The connector is sitting inside this plastic retainer/bracket. (may not be the exact bracket on the 94-95)
This is the two pin connector removed from the retainer. Showing the two female pins where you are to stick the ends of the paper clip or wire.
Old Apr 18, 2011 | 12:43 PM
Imma Try it sounds confusing to me really
Old Apr 18, 2011 | 12:56 PM
Well i found the one put the paper clip in and turned key on and my engine light just never stoped flashing i got to 80 and quit count
Old Apr 18, 2011 | 01:21 PM
Or i think it does it 4 times then goes off for like 3 sec and does it 4 times again over and over same pattern
Old Apr 18, 2011 | 01:53 PM
There can be a series of flashes. How many depends on how many codes are stored on the ECU'.
That same pattern that repeats itself between the pauses is what your looking for. The flashing will continue for as long as you have the connector jumped. It will keep replaying the same error codes.
long flash = tens position (first digit)
short flach = ones position (second digit)
3 second pause = signifies the start of the next code.
You could see something like this flashing at you,
long-long-long-short-short-pause-short-short-short-short-pause-long-long-short-short-pause and if that was the last of the new codes it will continue right back at the start.
Old Apr 18, 2011 | 04:19 PM
So should i right it down to remember all the ****
Old Apr 18, 2011 | 06:58 PM
You could try getting a manual.
hb_guy
Dec 23, 2012 04:42 AM
sunkship
Mar 10, 2012 10:02 AM
tedog69er
May 19, 2006 01:13 AM
Nufusion1
Sep 13, 2004 09:07 AM
slow02ss camaro
Feb 1, 2003 07:44 AM
