02 Accord EX--dashboard shorted and no crank
Old Apr 15, 2011 | 03:36 PM
TurbdEG6's Avatar
Default 02 Accord EX--dashboard shorted and no crank
Haven't posted on HT for awhile but I need some help...electrical is not my strong point.
I decided to install a keyless entry/remote start system myself to save some money. Everything was going smooth until the starter wire in the ignition harness ever so slightly touched ground about mid-way through the process. The wire sparked and that was all she wrote. Tested with a multimeter--nothing. The dashboard and head unit shorted and now the car won't start.
Should I call it a day and have it towed to a shop or is there a relatively painless and inexpensive remedy for this? Thanks in advance
Old Apr 15, 2011 | 06:37 PM
TurbdEG6's Avatar
Default Re: 02 Accord EX--dashboard shorted and no crank
bump
Old Apr 15, 2011 | 06:52 PM
02 accord's Avatar
See if you blew the main ignition fuse under the hood. From what I remember, it's either 50 or 80 amps.
Old Apr 15, 2011 | 07:23 PM
phootbag's Avatar
Agreed. I've seen people replace ignition switches, plug them in before screwing the switch to the cylinder and pop the fuse.
Old Apr 17, 2011 | 06:04 PM
TurbdEG6's Avatar
There it is. Problem fixed, thanks guys.
prodjay10
Honda Civic (2001 - 2005)
Dec 14, 2016 12:12 PM
VANGASKHAN
May 28, 2014 11:20 AM
fivebux
Apr 9, 2013 11:01 PM
thabadguy
Audio / Security / Video
May 24, 2010 07:48 PM
oioioimike
Mar 28, 2008 05:33 PM
