What size injectors?
Old Sep 28, 2002 | 01:56 PM
GapxGuy's Avatar
Sushi Buffet Champion
Default What size injectors?
B20 block
ITR head
ITR ECU
I/H/E
What size injectors do I need? Sorry for the noobie question, but I don't understand the size of the CC's, can someone please explain? Thanks guys.
Old Sep 28, 2002 | 11:21 PM
tinkerbell's Avatar
Default Re: What size injectors? (GapxGuy)
you should run stock, or slightly bigger than stock.
www.rceng.com/tech
knock yourself out!
t..
Old Sep 29, 2002 | 01:41 PM
AzG35's Avatar
With a B20Vtec, you should run at least a 310cc injector from what I've seen. That is the largest you can run on the stock ecu anyway, any bigger and you need to get a Hondata or something similar if you want to control fuel properly. Definately get larger than stock, that 2.0 liter w/ vtec demands a lot of fuel.
Old Oct 1, 2002 | 09:10 AM
Kataku2K3's Avatar
Default Re: What size injectors? (AzSi22)
310cc's on my friends CRVTEC, it has high compression pistons and a ported head with CTR cams, ITR ECU and VAFC for fuel correction.. 12.6@107 full interior daily driven in his EK. Latez
Old Oct 1, 2002 | 09:34 AM
Jeff C's Avatar
for my b20vtec i am runnin stock GSR's with 60psi of fuel pressure.
the a/f guage seems to be happy for the most part.
Old Oct 1, 2002 | 03:11 PM
tinkerbell's Avatar
Default Re: What size injectors? (Jeff C)
sweet! even under full load? eg a drag race?
t..
Old Oct 2, 2002 | 03:08 AM
Jeff C's Avatar
Default Re: What size injectors? (tinkerbell)
yea, under full load.
i ran it out to 8k in 3rd and 4th and the a/f was in the green.
however, i watched it on monday when i was cruising (70mph) on the interstate in 5th, the a/f was just in the red so i dont know but maybe the guage is off, but i pulled the plugs last night and they looked good...a little rich if anything.
eg a drag race?
what?
its a daily driven 89 crx if thats what you are askin about.
Jacknimble
Sep 7, 2006 07:18 AM
Sinner
Dec 23, 2003 07:09 PM
H22A EG6
Jul 3, 2003 08:39 PM
Zatar69
Nov 24, 2002 02:49 PM
Hybridhonda10
Apr 3, 2002 07:39 AM
