obd2b to obd1 injector wiring?
Old Apr 15, 2011 | 11:36 AM
dcrboost's Avatar
Default obd2b to obd1 injector wiring?
I am currnetly running a piggy back and a p28 to convert my type R from obd2b to obd1 but not sure if i have to wire up the rc injectors obd1 or will the harness do that for me. Help please
Old Apr 15, 2011 | 01:32 PM
00TypeR's Avatar
Default Re: obd2b to obd1 injector wiring?
with my s/c caR, I had the p28, harness, then the obd1 clips needed to hook up to obd1 injectors.
Old Apr 15, 2011 | 02:23 PM
R boy fresh's Avatar
If i can remember correctly You will either need either RC injector clips or Obd1 factory clips.. Rc doesnt make injectors to fit obd2 clips.. just get the clips and simply splice them to your factory harness.. GL
Old Apr 15, 2011 | 02:53 PM
dcrboost's Avatar
I have the rc injector clips but dont know how to wire them up, as of right know i have them yllw/black, yllw--yllw/black,blue--yllw/black,red--yllw/black,brow in that order
l l l l
l l l l
l l l l
cylinder 4 cylinder 3 cylinder 2 cylinder 1
Old Apr 15, 2011 | 02:55 PM
dcrboost's Avatar
I want to know if this is correct, Thanks any help will be greatly appreciated
Old Apr 15, 2011 | 03:10 PM
00TypeR's Avatar
polarity doesn't matter.
Old Apr 15, 2011 | 03:18 PM
94rs-turbo's Avatar
you could also get the injector plug and play clips if you dont want to cut your harness, btw you will have to trim out the inside of the rc injector for the obd1 clip
killerpenguin21
May 2, 2010 11:51 AM
turbodailydan
Aug 13, 2009 04:13 AM
redboost10
Jan 22, 2004 07:45 AM
Andre
Dec 20, 2003 09:38 AM
