NOOB Desprite Need of Help. NOOB
Old Apr 14, 2011 | 10:30 PM
Solster's Avatar
Default NOOB Desprite Need of Help. NOOB
OK i did some looking into this about 5 years ago to help a friend get his car Based so he could drive it to a REAL tuner.
any way i'm lost Now. i have
Crome 1.5
Freelog 1.0.93
Moates Burn1
HULOG Dattaloger and
a P28 ECU ZIF'ed and Switched for Chiped and Stock Use. (it has a Switch for JP1 so you can run it Stock or off the Chip)
Any way i have a 95 Del sol with a Mostly stock D16Z6 and i'm having problems with it eat Gas like a Hog (201 Miles on 12 Gal of gas) but No CEL so i was going to run the the Chipped ecu and datalog it to see if i can track down the problem but the chip i have is setup for a b18 and the car runs like crap (no $h17 right) but i can't get crom to install the QDL on a p28 load if i tell it to start a New File.
ANY idea what i need to do. i cant remember how i did it on the old chip.
also i can get datalogging if i use the old chip i just cant drive the car.
i do have a standalone AFR on the dash and it matches what the factory O2 is reading Via Freelog with the Crap Chip.
Old Apr 15, 2011 | 02:08 AM
Solster's Avatar
Default Re: NOOB Desprite Need of Help. NOOB
ok i Think i got it P28 Base doesnt support the QD+RPT so i used the P30 Base imported the tables from the P28 turned the o2 heat back on turned the O2 Back on added QD+RPT and removed the ckecksum set rev limit and Vtec to match P28 and turned off the speed limiter.
Did i get it right or did i miss something?
Deep.Fry
Sep 30, 2012 04:14 AM
preetyboi06
Dec 5, 2011 03:07 PM
Organization
Engine Management and Tuning
20
Sep 11, 2011 03:37 AM
tekcivic
Aug 17, 2006 07:58 AM
