Misfire
Old Apr 14, 2011 | 08:06 PM
Ct93CB7's Avatar
Default Misfire
ok so i have a 93 accord as i posted on here before wit a 97 ex f22b1... now i hooked everything up and the car runs.... i was getting a code 22 or 21 which was the cyp sensor.... so i wired in the original dizzy for it and wired in the tdc & cpk sensors down by the oil pan in.... so the car runs but its running only on three cylinders...wen i pull out the no.1 plug there is no change in the idle..... now i have tried everything i switched the injectors and swapped the no.1 injector wire that goes to the ecu wit the number two and still same problem.... the cylinder is getting spark and the compression is good but we think its not gettin fuel but i dont kno how that culd b..... if neone culd shed so light on this subject it wuld b great
Old Apr 14, 2011 | 08:21 PM
Ct93CB7's Avatar
Default Re: Misfire
What does that mean?????????
Old Apr 21, 2011 | 07:15 AM
Bailey511's Avatar
Default Re: Misfire
English as a Second Language?
Old Apr 23, 2011 | 06:17 AM
Ct93CB7's Avatar
Default Re: Misfire
would putting in obd1 fuel injectors change nething i have the obd2 ones on the motor running off my obd1 wiring harness... I read somewhere that they are different
turbohatchBnuts
May 12, 2011 06:14 PM
hialeahzbg
Jul 27, 2009 08:38 PM
ef8sleepr
Feb 23, 2006 09:25 PM
ww91crx
Jan 25, 2006 04:09 PM
superfuji57
Mar 15, 2004 02:23 PM
