90 Fuel pump
Old Apr 14, 2011 | 03:34 PM
journeyquest's Avatar
Default 90 Fuel pump
90 CRX. Is the fuel pump connectors in the spare tire area or more forward under the storage area? I want to test it but not sure what to pull out to get to it? Thanks
Old Apr 14, 2011 | 06:21 PM
JOE BD-0's Avatar
Default Re: 90 Fuel pump
You gotta drop the tank to get to the fuel pump on a crx. Good Luck.
Old Apr 14, 2011 | 07:17 PM
hondad6's Avatar
So what is the access under the storage, just the gas level sender unit? I have never taken it apart so i don't know, but i thought that it was the pump and sender. never mind yes you have to drop the tank here is the post i found https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/crx-fuel-pump-removal-2558936/. Also here http://www.cargurus.com/Cars/Discussion-t15693_ds450572.
Old Apr 14, 2011 | 08:31 PM
I dont want to drop the tank or pull the pump, just test the wires. Im sure it can be done without pulling the tank and removing the pump. Anyone here know whats going on?
Old Apr 14, 2011 | 11:01 PM
90efzc's Avatar
Nope, you have to drop the tank. Or you can cut a hole in the back interior directly above the fuel pump if you'd like. It's very simple to replace the fuel pump, just time consuming if you haven't done it before.
Old Apr 15, 2011 | 09:48 AM
tonythetuner®'s Avatar
If you want to test the wires pull out the back seats and under the seat you will see a metal plate With wires comming out there will be 4 wires, 2 are for the fuel pump and 2 are for the fuel level sender unit. Its been a while so I forgot wat 2 colors are fuel pump do a lil search I'm sure you can find out.
Old Apr 16, 2011 | 06:18 PM
My CRX doesnt have a back seat.
Old Apr 16, 2011 | 06:53 PM
uberEFtuner's Avatar
YOU CAN test your fuel pump by removing the *** pad(90-91), or storage compartment(88-89). The wires through the round plate are the fuel pump wires.
A-dub5513
Apr 15, 2010 04:28 PM
puertoricanboy90
Dec 26, 2008 03:41 PM
Crimson_Tide
Jul 27, 2005 04:24 AM
trooper0641
Jul 13, 2005 08:21 PM
spike
Jul 15, 2003 02:09 AM
