obd1 car and i want to use a obd0 ecu
hello everyone.well my problem is that i bought whole obdo b16a swap (came with every thing) for cheap and i want to swap it in my 92 integra. but my ecu wont work because the car is obd1. what can i do to make my b16a(obd0) ecu fit my car. i looked and looked but all i found is obd0 to obd1 jumper harness. i cant find one that goes to obd1 herness to obd0 ecu if anyone know what i cant do that would be great.
thx honda-tech
thx honda-tech
Seriously just find an OBD1 DOHC VTEC distributor and P30 ECU or chipped P28. Also swap your injectors over from you old engine to the new. Its really not worth it to go OBD0 plus it's probably illegal in your state to do so for emissions purposes. You'll also need to wire up your fan switch from the back of the block to the thermostat housing. Plus you'll need to wire up two O2's for the OBD0 ECU if you decide to go that route.
