fully built/sleeved/ls-vtec,how high should or can i rev?
i recently got a fully built ls/vtec off a guy and wanna know what i can rev it to?????????
here are the specs
b18b block:
micro polished ls crank
golden eagle 2.0L sleeved
eagle rods
arp rod bolts
wiseco 11:5:1 pistons 84.5 mm
ls vtec cometic head gasket to match
all bearings fresh,new timing belt,water pump,oil pump.etc..
7k on build as of now
jdm b16a head:
stage 3 skunk2 cams
supertech retainers and springs
arp headstuds
bolt-ons:
cf whale *****
bdl 70mm throttle body
eagle pro series fuel rail
lil bigger injectors cant remember
4:1 header
apexi wsp2 full exhaust
1st gen skunk2 intake mani
golden eagle ls vtec kit obviously
tranny:
99 ctr tranny with lsd
stage 3 unsprung clutch and flywheel kit
fully tuned on s300 on a dyno jet and made 224 @ 8900
now the question is if i wanna go to the track or get on it here and there,what can i rev this thing to 8900 since its tuned there? or what, i do want it to last,ive had a few a opinions face to face they say if it made power there and its tuned to there u can take it there? but idk thats why i got u guys lol i haven taken it past 8300 and that was only in first gear, any and all info it greatly appreciated thanks guys!!!!!!!!!
here are the specs
b18b block:
eagle rods
arp rod bolts
jdm b16a head:
stage 3 skunk2 cams
arp headstuds
bolt-ons:
cf whale *****
4:1 header
tranny:
I am pretty sure; you want it to last a considerable length of time and that is only going to happen if you meticulously maintain it like you would a PORSCHE,or a LAMBO without the service costs! I would also inquire to see if you could get an external (remote) oil cooler, temp. controlled fan, AN lines to and from as well as the remote filter relocation kit! It makes a hell of a diff when it comes to daily driven reliability!
Now as far as REV's go, there are a few key components that you have to make it possible to turn it up to 9,500 but, there are others that make it even more favorable but I can not reveal those as I am the LS-VTEC KING and secrets are what makes me money in the long run! I have a reputation for making them last till around 70k-90k of abuse with piston rings being the only drawback due to the rev's and rod/stroke ratio taking its toll on the most used parts of the internal combustion process! this is something that can't be helped with those RPM's being turned..........
My suggestion to you would be take it to 9k only in 1st and 2nd gear but stay within the 8,500-8,800 range for 3rd and 4th gear as to maintain the longevity quotient and reliability factor and you should be just fine playing it safe........I didn't see anything about the valvetrain bro...............I hope that you are fully prepared the correct way or failure may follow more unexpected than most!
You need common sense. If your car stop making power at 8900 why rev it any higher? please enlighten me WHY you would even consider doing that? cause its cool to rev high?
i dont wanna rev past 8900 i wanna know if it is safe to take it there is all,u know like here there when ever i feel froggy i shift at 8200 in first and second as of now just seeing if i can safely run it to 8800 or so with the build i got atleast in 1,2 like 8400,8500 in 3,4 lmk what u guys think
2n-chilli
11
Apr 15, 2011 07:35 AM
