Suspension & Brakes Theory, alignment, spring rates....
camber kit question help!!
Old Apr 14, 2011 | 06:09 AM
2n-chilli's Avatar
Default camber kit question help!!
i recently lowered my car a lil more its got full ksport coilsystem struts and all and front and rear camber kits,the front dont really look angled,but the back if u stand bout 20 feet away and bend down and look at both tires r stickin out
like so: / \ top is more inward then bottom,and i do have camber kit adjustable,how do i know when i have move it enough to correct the camber but not to much to b having negtive camber ne help is greatly apprec as u will have saved my tires thanks!!!!
Old Apr 14, 2011 | 07:21 AM
civexspeedy's Avatar
Default Re: camber kit question help!!
Alignment can't really be done at home(unless you have you own alignment kits or know how to do string alignments). So, stop messing with it and take it to a shop to get it properly aligned.
Old Apr 14, 2011 | 11:09 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Could we get some English in here please?
Why do you want to remove negative camber? You realize your handling will suck more with straight up 0 camber, right?
And yeah, you need to have it dialed in on an alignment rack. Or just toss those camber kits and put stock arms back on and not worry about your negative camber.
Old Apr 14, 2011 | 11:12 AM
2n-chilli's Avatar
its just the rear that looks like this: / \ help???
Old Apr 14, 2011 | 11:17 AM
Community Builder
I already told you what you need to do. Get it dialed in on an alignment rack, probably around -1.5 to -1.75° camber. Or just toss the camber kits, put stock control arms back on, and let the negative camber ride how it is at whatever ride height you're at.
Toe destroys tires, not negative camber.
Old Apr 14, 2011 | 04:39 PM
Libertariat's Avatar
Ek Forever y0!
Yay camber!!!
The guy at the goodyear store was making me so mad.
Tech: Is the car lowered?
Me: Yes, a little.
Tech: It's going to be $70 more for the alignment.
Me: What extra labor is involved since it's lowered? You're still just adjusting the toe.
Tech: No, kid, when you lower a car you have to adjust the camber, caster, and toe.
Me: Well, it's a good thing my caster and camber aren't adjustable then. Isn't it.
Tech: Your tires are going to wear unevenly.
Me: They've had similar camber for 6 years now and it hasn't been a problem.
Then he just smiled and said "okay okay"
Old Apr 14, 2011 | 06:24 PM
Tyson's Avatar
OP, do you have an EK? they generally have a lot of camber in the rear. you can just use a standard shim/washer type of "kit" to dial out some extra camber in the rear.
you really dont need to mess with the front camber. unless you have bent suspension. whatever its at, its fine. just go and get an alignment to fix toe.
and yes, this is the same advice everyone gets, i dunno why i keep bothering and repeating myself....
sublimeh215
Suspension & Brakes
Feb 10, 2009 07:34 PM
EJ6_Sedan
26
Mar 5, 2008 06:21 PM
vbspec
Oct 8, 2003 04:52 AM
SMC Integra
Jul 30, 2003 01:49 PM
jdmrealm
Nov 28, 2001 11:29 PM
