-----------GM Intake Air Temperature, IAT, Sensor with Neptune or Ectune-------------
Old Apr 14, 2011 | 01:32 AM
ACTION JACTION's Avatar
Default -----------GM Intake Air Temperature, IAT, Sensor with Neptune or Ectune-------------
Well I searched and I found 1 thread pertaining to this topic but it was rather old and inconclusive. I was hoping to have some light shed on running a GM IAT Sensor with Neptune/Ectune.
Also would a coolant temperature sensor be ok to use as an IAT? I ask because I found that a Saturn SC1 (97-01) 1.9L Coolant Temp Sensor is 1/8" NPT and same scaling as GM IAT.
And a Saturn Ion (2004) has a coolant temp sensor that is 1/8" NPT AND has GM IAT style plug...
These are what I found from my research and was hoping to discuss
Old Apr 16, 2011 | 01:54 PM
Turbo-LS's Avatar
Default Re: -----------GM Intake Air Temperature, IAT, Sensor with Neptune or Ectune---------
You're not going to be able to run a GM intake sensor on a oem based ecu tuning system. You really dont need a faster intake temp sensor. Best thing to do with the temp sensor is get a bung from xenocron, weld it into your charge pipe right before the throttlebody. this will give you accurate intake temps instead of heatsoaked intake temps by mounting on the intake manifold, also a thermogasket works wonders for heatsoak
Old May 17, 2011 | 03:48 PM
Yeah, I kinda ditched the idea. lol
ROOSTER.
Jan 31, 2014 05:42 PM
LuckyJDM
Dec 8, 2012 10:28 PM
SixguN
Mar 4, 2005 11:34 AM
BuddyC
Apr 20, 2004 04:54 PM
supernova
Dec 3, 2001 06:49 AM
