Sohc zc fuel injectors
Ok i just bought a ef8 rex 88 si, and the last owner said that the motors injectors where change to prelude injectors? runs clean tho no problems, besides the white smoke and a ecu code of a 1 02a oxygen sensor #1 and a 43 which says fuel supply system, i was wondering if i can tune it to fix this or just go back to the original ones? also can i get the injectors from any single cam d series 1.6 or ?
as far as i know prelude injectors shouldnt cause a problem... not 100% sure bout that tho, check to make sure you have a resistor box if youre still running obd0, and any d series injectors will work given theyre the same obd's as what you have, and what do you mean besides the white smoke lol
