built all motor on E85. oil changed every 2 months?
Old Apr 13, 2011 | 08:22 PM
Tong.Y's Avatar
Default built all motor on E85. oil changed every 2 months?
is it true that if your motor is tuned on e85.. it's recommended that oil is changed every 2 months? any other heads up for e85 tuned and running motors i should know about?
Old Apr 13, 2011 | 09:26 PM
ptftw's Avatar
Default Re: built all motor on E85. oil changed every 2 months?
i change mine every track day or 300 miles.
Old Apr 14, 2011 | 08:44 AM
Tong.Y's Avatar
wow.. i have not changed my oil since the day i bought it in feb. but now my car is burn oil on every cold start up.. when its warmed up everything is fine.. i guess i need to change to thicker oil
Old Apr 14, 2011 | 08:50 AM
Tong.Y's Avatar
plus my oil is still looks clean.
Old Apr 14, 2011 | 09:51 AM
96dxB16's Avatar
I change the oil on my E85 Evo every 5,000 miles.
Have yet to change the oil on my E85 Honda, has only 50 miles on it so far.
Old Apr 14, 2011 | 10:50 AM
Tong.Y's Avatar
e85 doesn't get as much carbon deposits as unleaded gasoline.. why is it that e85 needs its oil changed sooner?
Old Apr 14, 2011 | 10:58 AM
96dxB16's Avatar
I don't change it any different than when I ran gasoline.
Old May 1, 2011 | 08:49 PM
STRATTON's Avatar
any of you guys mind sharing your mpgs and hp levels your expriencing with e85.
stratton.
Old May 2, 2011 | 06:05 PM
ddd4114's Avatar
E85 will dilute the oil faster if you take lots of short trips and not let the crankcase heat up enough for it to evaporate.
Old May 5, 2011 | 05:36 PM
STRATTON's Avatar
guys care to share the gas mileage your experiencing with the e85 ??
stratton.
Old May 5, 2011 | 06:35 PM
Krut's Avatar
stratton.
20 MPG here around town, H22A w/ bolt ons/ITR tranny in EG hatch
Old May 6, 2011 | 01:23 PM
STRATTON's Avatar
thats good imho, considering the gains that you can get out of the fuel .
anyone else care to share ?
stratton.
Old May 6, 2011 | 01:55 PM
96dxB16's Avatar
16 mpg in a 370whp Evo.
Old May 6, 2011 | 02:05 PM
Garage 808 Hatch's Avatar
^^^ why are you happy about that?
Old May 6, 2011 | 02:32 PM
96dxB16's Avatar
I put the smiley because it was the mpg of an Evo not a Honda. Not sure if it was a relevent comparison.
Why do you ask?
Old May 7, 2011 | 08:44 PM
Krut's Avatar
stratton.
I'm happy. On 93 I was getting 25MPG, I was expecting a much larger hit honestly, its nice paying a doller less per gal so I think I'm saving money haven't done the calculations though. Runs great on the E85
I would say that's very good, considering a stock EVO gets like low 20s maybe at best on regular gas? with much less power
Old May 8, 2011 | 06:53 AM
96dxB16's Avatar
yes, not bad at all. to give comparison a stock evo dyno's around 220whp on that dyno i put 370 down on (mustang).
Old May 8, 2011 | 08:04 AM
SiLkk's Avatar
Been running my k20 on e85 for a year now. Still do 2,500ish mile oil changes
Old May 8, 2011 | 09:12 AM
STRATTON's Avatar
no thats good imo. what kind of power does your h make ?
whats the mpg and power level your at ?
thanks for everyone posting up there info. i feel like more people should post up power levels and mpg regarding e85 so that alot of people will have a data base to look at and compare etc.
stratton.
Old May 8, 2011 | 07:16 PM
Krut's Avatar
stratton.
218/165 Mustang dyno
Old May 9, 2011 | 06:39 AM
STRATTON's Avatar
mustang dyno's tend to read higher then other dyno's, how was the tune, really aggressive or mild ?
stratton.
Old May 9, 2011 | 08:51 AM
Krut's Avatar
stratton.
I always thought mustangs read lower then dynapacks/dynojets but at the end of the day there just numbers.
Not really sure, I just sorta let the tuner do his thing, afr's are at 12.9-13.0 that's all I really know, I don't know much about tuning
Old May 9, 2011 | 09:19 AM
96dxB16's Avatar
Yes, mustang dyno's read lower. Any dyno is just a tool.
Old May 9, 2011 | 09:27 AM
MikeySpec's Avatar
On all motor honda's we see an average of 20-25mpg on e85. Lean it out, add some timing for cruising loads - its a good difference.
Old May 9, 2011 | 12:53 PM
STRATTON's Avatar
you guys are right, i had it backwards mustang dynos read lower.
its very good to hear that guys are still getting nice mileage. it ends up being the same in the end power vs milage, you just have to stop at the pump a bit more often.
all we need is all pumps to start carrying e85.
stratton.
